Crolls Ultramatic 52 Front Load washer
Response to Brent-Aucoin
THE WATER GOES UP JUST A LITTLE BEFORE THE MIDDLE OF THE DOOR WHEN USING THE HIGH LEVEL AND YOU CAN BEARLY SEE IT WHEN USING THE HALF LOAD. I NEVER CHANGE IT FROM HIGH SINCE I JUST LIKE DOING WHOLE LOADS. I WILL TAKE SOME VIDEOS AND SEND THEM LATER. ANOTHER THING THAT AMAZES ME, ARE ITS SOUND. THEY ARE VERY PECULLIAR FOR THIS BRAND. WHICH EVER CROLLS YOU HEAR, EVEN THOUGH YOU´RE NOT WATCHING AT IT, YOU´LL RECOGNIZED THEM FOR THEIR SOUNDS. HOPEFULLY VIDEO CAUGHTS THE SOUND ON THE DIFFERENT STAGES.
Re: Welcome Ultramatic52:
Hi! Ultramatic52, welcome to the AutomaticWasher Club Site. What an interesting, great looking Washer. I've never seen a basically "Flat" top area with the Controls on a Front-Load Washer before. Can I assume that it is on Rollers, seeing that you seem to normally have it sitting to the right of your WP Dryer. "BTW" are your WP Washer and Dryer the Calypso or Catalyst Models? I remember seeing those Consoles but I don't remember which Models had them.
Thank from me as well for sharing your Pix's of your Crolls Washer, as well as of your WP's too.
Happy Crolls and WP Washing and WP Drying, Steve
SactoTeddyBear...
P.S. Mind if we know what general area that you live in of Mexico and at least your actual first name...
Re: SactoTeddyBear
My Crolls lays on the concrete floor but its not too heavy to me moved away. I moved it to take some front pictures and inside pictures. By the way because is not too heavy ,although it has 2 huge heavy rocks inside, sometimes when it gets out of balance, in runs away from its place. Hoses are the only thing the keep it from going to the garden or all around the house. This machine doesn´t have the technology to rebalance the load, so it won´t stop spining unless you turn it off or the cycle ends.
I live in Mexico State which is 30 min away from Mexico City. My real name is Cesar.
SactoTeddyBear
I´m sorry I forget to talk about my Whirpools. Washer is the Catalyst model and Dryer is Senseon model. Calypso washers and just garbage, they actually get clothes dirtier than before washing. No detergent is removed from clothes after several rinses and after a couple of loads you`ll begin to get your clothes ruined. The ones I owned have 3 timed dispensers for Detergent, Bleach and Fabric Softener just as Crolls, so you just load everything (clothes, liquids and so), turn it on and forget about returnig to the washer until the chime rings to indicate it has finished. They are also beautifull. I will post some pictures of the inside later.
Question
Does anybody know how the Maytag Neptune MAH9700 performs and its quality? I´m really thinking on buying one since we have King Size and Queen Size comforters that don´t fit in our Whirlpools neither Crolls. I´m tired of paying to laundromat where they doen´t clean comforters as my Crolls will if they would have fitted.
Thank for the water level talk. Sound dramatic!
I love the shots of your back of the washer with the back off.
Man! That is a huge motor! Looks like it could really handle a huge load!
Thanks for the pictures!
Brent
That Crolls sure is a cool-looking machine! They do have some interesting washers in Mexico (single tubs and semi-automatics), but I never had any idea that brand existed! It must be FUN to watch on the high water level...I can imagine the splashing!
Re: Brent
It does handle pretty huge loads comparing to whatever actuall compact front loader. The only thing missing is higher spin speed. It spins at 430 RPM, so I can bearly put the load I wash in it in the Whirlpool Dryer. Before I bought the Whirlpools, I used to have Magic Chef machines which were the best machines I could ever own (huge capacity, lots of features, superb reliability) but even though, the motor of the dryer was blown out because of Crolls´ low spin speed. This was after 5 years of minimum 2 daily loads. Magic Chef washer never needed anything. AWESOME MACHINE!!!!! I just bought new ones because I wanted to have LED control panels and the only choices I had at that time were Whirlpools which I don´t regret.
Changing the subject, although it sounds to use a lot of water it only uses 3/4 of what the Whirlpool will use for only wash cycle for a full load (26 gallons + 26 for rinse + 26 for optional additional rinse). This means it uses aprox 22 galons when you wash from letter A to letter G which includes a 1 hour presoak with constant agitation ("A" for very dirty clothes), 12 min prewash ("B" for dirty clothes), 1 hour aprox of First Main wash (because of heating delay and depending on the temperature you´ve chosen(letter "C" for Normal Whites or Colorfast)), 35 min Second Main wash without any heating ("D" for color clothes), 2 rinses of 8 min each with spin ("E"), 1 last rinse for fabric softener of 4 min ("F") and 8 min final spin ("G") giving us a total of 3.25 hours aprox. I only use letters "C" and "D" because for my loads is all I need and it just uses 17 galons till the end. 3 tablespoons of Detergent and 1/2 of cup of Fabric Softener
Ceasar,
I am really starting to like your Crolls front load washer more and more each time I look at it, and read your post.
Do you ever see these machines used? It would be great to pick one up, if you could find one. I am sure that it would be worth it.
Can you still get the parts for this washer?
I have friends in Mexico City. I am going to tell them to be on the look out for this brand. I am sure that they will think that I am crazy when I ask them.
Brent
Welcome aboard, Çesar. Yes, the Crolls looks like an excellent unit, very sensibly designed, and well-built.
I have a dumb question (I should know the answer but I don't): what is the mains power in Mexico? Are you on 120 volts at 60 hz, or some other voltage & frequency? This will be relevant to folks here who might want to buy older Mexican machines.
What other brands and types are in common use there? And what kinds of older machines are found at used appliance stores?
Re: designgeek
The power we use here is the same used in the US. Actually it´s really weird to find someone that uses 220V. Just factories I guess.
It´s a shame there are no Old Appliances Stores here. When people throw away appliances, they usually get new ones for little prices. You can get an excellent washer for 200 USD or less that can last a life time. Sometimes people prefer to buy semi-automatic machines rather than automatics because of repair costs, lack of space, water waste. Don´t know but there are thousands of excuses for not buying automatics.
The brands that we used to have (the best ones ever, well made, durable, excellent cleaning performance, etc)were Easy Golden Line Automatic Washer (Spirilator agitator). After a while its factory decided to stop producing Golden Line and then produced another model which has a kind of Spirilator agitator and into it you can fit a mini washing basket (it was very alike to the Old GE Filter flow with the detergent dispenser on top of the agitator). This washer was still awesome but was produced for just a couple of years. After that they introduced the double duty agitator and its junk ID system which is suposed to detect the fabric type, weight and soil levels. In my opinion this thing sucks, it doesn´t get your clothes clean, they break off easily, they select the amount of water they supose they need and so much more. I think we should control the washer and not the washer control us.
There was also another brand called Bendix Aquamagic which was top load and it had an agitator like the 3 ring Frigidaire, but this one had just one on the buttom of the tub which had a wave form and a blue color, and it had a huge cylinder filter on top of the wave ring which could be removed to clean the lint.
Another is Koblenz which can also clean excellent and last for at least 20 years.
Some other brands are IEM (semiautomatics), Twin Tub Easy, Mabe, Acros, Supermatic. The last 3 have almost the same shape as portable Whirlpools have. After that Whirlpool was introduced in the Mexican market and almost all this brands desapear. Actually they continue producing Easy Id System, GE Id System, IEM (junk), Acros (junk), Crolls was discontinued 10 years ago because Whirlpool bought the company to enter the country and they stopped producing Crolls.
By the way, my Crolls was the last one produced all around the country. I bought it directly from the factory and the engineer told me that was the last one they have all around the place. That makes me prouder of my washer. It´s a pitty that when you need any parts, its really difficult to find them, they don´t produce them anymore. You can find them but they won´t be original. Mine hasn´t need any big repair, as a fact it has´t required any reapair at all. I just painted last summer and thats all.
The actual market is Whirlpool´s, Maytag´s, LG´s, GE´s, Easy Stupid Id System, somewhat Kenmore´s and thats all you can get here. There are some other brands also for sale but they are not worth writting (they SUCK!!!!!!!!!!)
PS. I will look for some pictures of the brands I find, and will post them.
Re: Bendix Aquamagic:
Hi! Cesar, the Bendix Aquamagic you discribed sounds like our American Washer, that was called a Philco, which was a Ford Product. It had the same/similar single "Flapping" Wash-Power Ring on the Bottom, with the removable Lint-Filter above that. The Philco Washer came with the Lid opening from Left to Right, instead of Right to Left, much like several of our American Model Washers opened, other than opening from Front to Back, as quite a few now have.
One of my Relatives lived quite some time ago in Mazatlan and they were in need of a new Washer. Their Father bought them a new Easy Washer with the Spinner and when he came back here from his visit and purchasing that Washer for his Daughter, he told us he had to pay $750.00 {American} for it and that was somewhere around the Early to Mid 1980's.
Peace and Happy Crolls and WP Laundry Days, Steve
SactoTeddyBear...
Greetings, Çesar!
Loved reading all your info. Wow, 3.25 hrs for a full "A" wash program on your Croll. That's some serious washing! That huge WHIRLPOOL logo across the front of your Catalyst is fun!
Sounds like Easy's "ID System" is similar to the automatic fabric and water level sensing on Fisher & Paykel's Intuitive Eco washer.
And another marketing term "Aquamagic" revealed for the Philco/Bendix machines. Great!
Welcome to the Club, Cesar!
It's great to have a club member from Mexico! From all of the information you have posted so far, it sounds like you will fit right in! Although I've never been to Mexico (I live in Texas), I have always been interested in Mexican washing machines. When I buy Mexican Ariel laundry detergent, I always see the brands of washers that you've mentioned above listed on the bag of Ariel. I would love to see pictures of these machines if you happen to find any.
I also have some questions about Mexican detergents, which I will post in the "Super" forum, and hopefully you can give me some information on these.
Once again, welcome to the Club, and I hope to see more posts from you in the future!
Tex
Brent-Aucoin
Where do your friends exactly live? Because there are several stores located down town where they can get re-builted Crolls washers. I don´t know if there are any Ultramatics as mine, I´ve never seen them, but I do know they have some other models (Novomatic) which could be painted in the color you want. They are sold for $ 150 USD maybe less, I guess it depends on the model you choose. They really look awesome. Maybe they could also find some other brands which are also great as Easy Golden Line or Bendix Aquamagics. They have all sort of washers and their replacement parts.
Welcome
hi cesar....welcome to the club...do you ever get to tucson, arizona??...there are 3 of us club members here and we are always getting together to do laundry...will send some pictures to you by email....if you come this way, please let us know....we are starting to use mexican detergent...it still has phosphates and they clean very well...
we are doing big wash in march 31, 2006 to april 3, 2006 and you certainly would be welcome.....ross
Welcome to the club! That is a very interesting machine. Thanks for all the neat pictures. Terry
Welcome Cesar
Hi Cesar, great machine! Thanks for all the info and pix. I'm new to this site too.-Welcome-James
Big Wash In?!!
Hi Ross,
What's this about a Wash In???!! Is it a 'convention' of sorts or what? I have way too much vacation time on the books and I'm being forced use some up!! I would love some info if it's a public thing.
Thanks!! --James
