There's Revere, and There's REVERE....
Hans,
The Revere you gave away sounds like it would have been post-1965 production. In that year, Revere cut the thickness of the copper plating in half. The cookware looked the same as ever, but it did not perform anything like the same. The situation was very puzzling to a lot of young cooks (including this one) who had heard Revere extolled for years, and when they got some, found it to be very problematic cookware.
If you get your hands on Revere made before '65, you will have yourself some righteous pots and pans. The way to tell if you have old, heavy Revere worth owning is to look on the bottom. If you see a large logo containing the words "Process Patent," you just made Bingo.
If it does not say "Process Patent," it's post-1965, and it's not worth your time or money. The thinning of the copper layer was bad enough when it first happened, but later on, it was cut even more, so that it is now a thin, thin wash of copper that is more or less purely decorative.
Again, the words "Process Patent" on the bottom are the key.
