Cutting Off Water Supplies
johnrk
Oct 3, 2017
696
BP TX
Looking through the vintage washer manuals that I've purchased on this site, all of the early ones for autos caution that the operator be certain to cut off the hot and cold water taps after each wash day, then turning them back on the next time the machine was used.
I've always turned my taps to the washer off when I've gone out of town, but certainly never do it on a daily or weekly basis.
Was there some point in the past when people quit doing this task every wash day?
Old valves can leak. I have a WO-65-2 that will drip a bit of cold every now and then. Enough to put a quart or two in the bottom of the tub within a day or so.
When I had the basement plumbed I had lever-style main cut-offs installed. Makes it easy to just shut everything off when I am through with the wash day.
my laundry room has main valves to shut the whole room off since there are so many machines....
safety first...always!
a few seconds to turn a valve, or hours of clean up and water damage....
it is recommended to replace the hoses every 5 years, but who really keeps track of that?....
there was a time, such as going on vacation, to shut down just about the whole house, water gas and electric....
remember during an electrical storm to unplug certain appliances, Refrigerator, TV....
there was a bad storm here about a year ago.....everyone thought I was nuts running around unplugging everything.....after the storm, two of my neighbors lost quite a lot....TV, computers, washer, water heater....for them, insurance doesn't cover those items from storm damage...
don't just flip the breaker, pull the plug!
may be a bit of overkill on my part....until you see the kind of damage that can occur...
I've never turned off the valves, never even given it a thought. Mind you I do have a basement location next to a floor drain for my washer. Use quality hoses and keep them in good condition and a failure is darned unlikely. Manufacturers are likely to suggest turning off the supply because it can limit liability if the machine were to fail, "We told you to shut it off in the manual"...
As for metal braided hoses, these are mostly feel good window dressing. Hoses don't fail in the middle of the hose unless they are damaged (the metal braid may help here). Hoses are more likely to leak/fail at the end. I'll take a name brand known quality rubber hose over a China brand metal braided hose. The manufacturers have done a good job of fooling the buying public of possibly buying a lesser product with something shiny in this case.
I too have never turned off the water to any of my machines.  Never saw the need.  True, my stuff is in the basement, but doubt I'd worry if they were not.  Hoses are quite durable, unless something is really off balance they never see any movement, they are not repeatedly disconnected and reconnected as a garden hose would be, so little wear and tear.  Not a bad idea to replace them every 5-10 years but some of mine are 20+ and fine.
