radioboy75
Member
My DE806 will not turn off even when the clothes are dry. My wife said it has run more than three hours and when she finally stopped it the clothes were very dry.
I have done several things. I have soldered the wires to the terminals. I have replaced the capacitor. I have tried running the damp dry cycle. It keeps running. We tried the removing the yellow wire trick, which should make the capacitor charge quickly and shut off the dryer after less than a minute. It doesn't.
A couple of interesting wrinkles. The air fluff cycle, which is supposedly timed and is supposed to shut off in 10 minutes or so -- doesn't.
Also, after we ran the test cycle in damp dry (yellow wire attached), my daughter reached into the drum and touched the wires on a baffle, and got a shock.
So I'm wondering if this is a grounding issue. Maybe I'll try that. But does anyone have any other suggestions? Could it be the control? Especially since even the air fluff cycle (not connected to the moisture sensing circuit) doesn't turn off either?
