Another difference between the TC5000 and the Series 9 (or 9 Series if you prefer):
I am forever grateful to Malcolm (mrb627) for posting this hack. You can skip to the next part of any cycle simply by pressing the WHITES and PERM PRESS pads simultaneously. I use this wonderful little hack frequently. It provides the all the flexibility of a mechanical timer. You can jump around in any cycle simply by pressing a couple of pads.
Case in point: Most small loads deserve slow agitation and require only spray rinses. I also like to wash loads of colors (shirts, dress shorts, etc.) the same way. I choose the BULKY cycle, let it fill and agitate, then return to the machine, power it down, select NORMAL ECO and press start. Agitation begins immediately because the tub is already filled. I press WHITES and PERM PRESS together and the machine jumps to the spin-drain/spray rinse portion of the cycle.
Does anyone know if there’s a way to advance to the next operation in the cycle on the TC5000?
brisnat81: Thanks for video of the vintage Fisher & Paykel. Are today’s F&P washers made the same way? Agitation in the video has the same distinctive sound I hear in videos of the brand’s newer machines.
thomasward00: Since most of your laundry is lightly soiled, the TR fits your needs—especially if reliability is your primary concern—and it’s very quiet, as well.
[this post was last edited: 9/18/2019-07:22]
