Dishwasher Brand/Model Recommendations?
pumpkina
Sep 2, 2017
100
California
My 1998 Bosch dishwasher stopped working. I don't know much (really anything) about dishwashers.
What brands/models do you recommend?
Should I get an extended warranty?
What preventive maintenance should I be doing?
thanks!
Thanks.
I read that the Boschs' dish racks are too closely spaced. I took my dishes to Lowe's and confirmed this on the Bosch, but not the Whirlpool.
I'm afraid of GE, given their bad rep with refrigerators, washers, and dryers.
I'm quite happy with my Miele dishwasher. It's a MOL model but it has a lot of things that I like. A water softener, a top cutlery rack, adjustable racks, etc. It even has a "tab" function and an express function.
Only thing that took some getting used to is that a normal cycle takes about 2.5 hours to run, while I'm much more accustomed to Whirlpool/Roper dishwashers taking somewhere around 40 minutes to do the same job.
The only thing I don't like about Miele dishwashers honestly, outside of the slow cycle speeds, is the cost. They're fairly expensive in comparison to other dishwashers on the market.
I've heard mixed reviews about Bosch, some people love them, some hate them.
The best personal experiences I've had with dishwashers outside of Miele was Whirlpool, (Back when they sold the Inglis brand in Canada) but I have no idea what kind of quality their modern machines have.
All I can
recommend is one with nylon racks so they won't rust. Nylon is more durable than the softer vinyl racks.
I purchased a dishwasher last in 2011. A GE Profile 4 cycle with a plastic tub, nylon racks, and a stainless front. No problems yet.
The vinyl racks on my former Whirlpool Gold were already starting to rust at 7 years old. It only worked on the normal cycle for two years.
Thanks
How can I tell the difference between nylon and vinyl?
I thought that only iron rusts? Do vinyl have iron in it?
Thanks
Thanks, pierreandreply4
Where can I find that?
What model years of KitchenAid dishwashers do you recommend?
Any particular features (eg plastic vs stainless steel) should I look for?
Thanks
And I would suggest exactly the opposite. Why buy something that is yesteryear's best when there have been many improvements on new appliances now. The 4 year old Whirlpool made dishwasher I got from Sears (practically identical to a new high end Kitchenaid model) does a terrific job of cleaning. It is also whisper quiet. Much better than my experience with Kitchenaid in the past......[this post was last edited: 9/20/2017-11:48]
<blockquote>Pumpkina:  I thought that only iron rusts?  Do vinyl have iron in it?</blockquote> The vinyl coating doesn't rust directly.  It deteriorates (more readily than the more robust nylon coating), which exposes the metal structure of the rack, which then rusts.
I am a huge Miele dishwasher fan. I sell a ton of them. I have two of them. I have definitely been drinking the koolaid.
That being said, if you don't like how close the Bosch tines are, you probably won't like the Miele.
My next step down from the Miele is generally the KitchenAid units that have the clean water wash system. It is sort of a hybrid between their new filter wash system and the wash system that is in the new Maytags. It has a larger pump than the filtration machines, but it has a self-cleaning filter that flushes the debris away when it back flows for the drain. I also like the KitchenAid ProDry which lets you use a fan-based air dry or heated and fan dry.
We are not a fan of GE's dishwashers. We don't have good reliability with them. We see a lot of electronic issues.
Frigidaire seems to make a pretty decent budget machine. We always have mid-range Electrolux units on sale, they feel like they are built very well.
Basically, it all comes down to what you want your dishwasher to be able to handle.
http://https//goo.gl/photos/McdPVWrhPmCv5U7d7
I love my Miele.  I got it used at the ReStore.  It made me forget quick about the vintage KA and ISE machines I owned previously, and since I almost always run it after dinner, I don't care how long it takes to complete the job.  What I do care about is clean, sparkling dishes and, in particular, glassware, and the Miele is superior in this regard.
I used a Bosch in a vacation rental and absolutely hated it.  It was flimsy and the rack design was both aggravating and a pitiful use of space.  There is absolutely no comparison or contest between Bosch and Miele, IMO.
You have a really good ReStore in San Carlos that has barely-used high end appliances from trophy homes on the peninsula that are being gutted yet again by new money (on paper) techsters.   Go see what's there.
in term of kitchen aid if you went vintage i recoomend
for vintage i would reccomend a KDS-57 the lucky part is if you find a portable you can convert it to built in and if you move 1 day to a place whee you need a portable dishwasher you can convert it back to portable and in a vintage dishwasher the inside is porcelain and if you went a more modern model i would recomment for a more modern version this model with a window that way you can see if the dishwasher finish its cycle and lots of members here can reccomend you a good vintage dishwasher that would give you years of use
http://www.kitchenaid.ca/fr_CA/maga...vaisselle-3/-[KDTM384ESS]-5667596/KDTM384ESS/
