Hmmm I would have assumed that air-shutters for coal burning are non-electric and use a bi-metal thermostatic damper control. Unless there was an auger-screw electric coal-feeder coal burning was not normally electrically controlled/regulated, IMHO.
The beauty of coal-burning steam-generating central heating systems systems (as were typically found in NYC) is that they were totally non-electric.
I would further assume these pictured to be electrically operated and for a gaseous or liquid fuel.
Gas burning conversion heads are known as power-burners (they look like oil-burners)and deliver a ball-of-flame in one location rather than a more typical designed-for-gas furnace or boiler which has a number of gas burning tubes or jets that spread out the flames. The power burners typically have a fan to push secondary combustion air into the combustion chamber, and to induce a positive draft. Of course the (non-powered) gas venturi used to mix in primary air for combustion is normally outside the combustion chamber.
