Luckily I was home and had not gone to sleep yet! I started a load in my 12 year old whirlmore direct drive washer & went into the other room. About 30 min later I needed something from the garage & SURPRISE I step in a bunch of water! The washer was just filling continuously and running all over the laundry room floor, into the hallway & half bath & under the door to the garage. (Wood flooring in hallway & half bath, ACK) Stopped the washer, turned the timer to drain & proceeded to clean up the mess with the wet dry vac. I know I could probably replace the pressure switch, but the machine is 12 years old and this is the second time this year it's needed repair. I think Momma's gettin a new washer. There's some damage to the wood floor, not too bad though. We'll have to see how it is when it dries completely. The real reason I posted this though is to remind everyone never run appliances when you're leaving the house or asleep. I know it's common sense, but I admit I've done it in the past. Also 2 weeks ago my parents Asko dishwasher nearly caught on fire. Turns out there was a recall on the control board that they didn't know about. The repair person that came to replace it said he'd just replaced 30 of them in a nearby condo building and my parents was the first one he'd seen that had actually been charred! Luckily the were also at home when it started smoking!
Virginia
Virginia
