Double Header and not at Fenway Park
toploader55
Oct 10, 2007
7,091
Massachusetts Sand Bar, Cape Cod
Well, I broke down and went against the one in and one out rule.
I recruited John (coldspot66) as we had to catch up after a year of bad timing and me working too much. So off we go to Swansea.
Although I will be parting with a few machines over the next few weeks.
Here is the KD4-P.
The Machine is Pristine and Minty except the Drain Pump doesn't work and we have detected a (Hopefully) Minor leak.
Here we go. These are Pre Clean up
The Schmuts near the bottom right chrome strip is Old Scotch Tape. (WTF ???)[this post was last edited: 4/28/2013-19:00]
Shiney
Big Blue still has Blue Paint on the inside of the Spray nozzles. Very Low use, and has had Gasket Torture by little to low use. (Hence the Leak)
The Drool on the rack and the bottom wiped right off. I nearly had a stroke thinking it was rust but Nope.
I do need...
If anyone has a spare, Lid for the Detergent Cup.
It's always strange on Low Usage Machines how the most weird parts can be missing.
Oh yeah, it has a Rinse Aid Dispensor too.
Two Cycles... Rinse and Hold and Full Cycle.
