Downy
I love Snuggle too, I am currently using the scent you mentioned and am enjoying it... but ohh how I remember the 'cuddle up fresh scent' I miss it
washer oversudsing?Quick,add a little Final Touch to reduce
I was happily surprised to see that Final Touch has been reintroduced to the market!
Too much suds ruins the dudds. it makes a mess too. Add a little Final Touch to reduce the foam."
I used to see these small 4"X 4" signs in all the laundries that had the front loaders.
Adding fabric softener to reduce foam.
It's good to use to knock down suds but less detergents should be used to combat this minor problem.
With a front loader, the second rinse should be suds free but with a hint of a white ash look in the water or none at all.
Sometimes it's the machine leaving suds in the sump area causing redeposits.
If suds are seen during the third rinse, it's time for a change in detergents!
