Detergent choices
Thank you, Bob.
The prices on AMZ are all over the map. The normal high price is  $54+. I paid $46.74 for it, and the price dropped today.
I'm a little upset that the box leaked from the un-tape areas.
Also, I did my first load with this detergent, using 2 TBS, and the water was very slippery to the touch. The scent is strong compared to other Tide products.
Thanks again.
I paid $49 canadian a few months ago on the Staples Canada website... today it's on sale for $39 canadian which is about $29 USD. Amazon in the US & Canada it' still around $50 both US & Cdn.
btw the box isn't plastic lined. Mine hasn't leaked out but the smell certainly does. I actually offered it to my neighbor but she declined after smelling it and she likes things like Glade plug ins etc. I won't use it at all on my sheets and pillow cases and use it sparingly on regular washes with added extra rinses.
Bob- Just wanted to check in to ask for your thoughts on powdered Tide Professional now that you’ve had a few weeks to get acquainted with it. I really like it. It’s a top-notch cleaner and the scent doesn’t bother me. It’s fairly strong straight from the box, but there’s barely any residual scent when items emerge from the dryer.
If I had to choose one powdered US detergent to use, it would be Tide Professional.
Eugene, I love it. Have been really impressed. I think somewhere in the original thread(s) discussion the product, it's formulated to perform best with warm water. The limited thus far expsoure to difficult stains, it's performed flawlessly. And rinses well. As such, my two go to cycles are towels and perm press for the rest of laundry. Those two cycles use lots of water and warm wash temp as default. In a lot of ways laundry has been vastly simplified compared to my almost OCD approach of the proper temperature and cycle for the various sorts of loads
I’ve really grown to like Miele UltraWhite. Probably the best detergent for white fabrics that I’ve ever used. Super concentrated. It makes me wonder about the dosing directions on the Miele package. I’d never be able to get good rinsing if used that dosing. My water is 14-15 gr/gal so pretty hard and I still need to use very little.
Bob
do any of you use baking soda with your laundry detergent? I only ask because I found a huge bag of Arm & Hammer baking soda from costco unopened... I've been adding about 1/2 cup in the drum and then my regular detergent in the dispenser... and then vinegar in the rinse dispenser.. I really just wanted to get through the big bag of baking soda and I'm kind of surprised but I think it makes a difference...
I'm also almost out of laundry detergent. I'd say I have a month's worth left and I have NO clue what I'm going to try next.
"A touch of Downy"
P&G formulates "Tide + Downy Free, liquid detergents with cellulase enzyme and bit of castor oil and or soap.
https://smartlabel.pg.com/en-us/00037000874737.html
Former chews away at bobbles and helps soften fabrics among other things.
https://biosolutions.novozymes.com/... by gently,brightness of worn cotton surfaces.
Latter adds extra softness to wash same as back when soaps were queen of wash day.
Remember? Ivory Snow gets clothes softer than detergent. Well that "softness" came from oils and fats used to make soap which leave a residue on fabrics. Early fabric softeners were merely emulsions of tallow (beef fat) and other oils that pretty much did same thing. Nowadays many TOL softeners use surfactant technology instead of or mainly instead of relying upon fats/oils to less affect absorbency of textiles due to aforementioned residue. Over time that soap residue could build up leaving things with "tattle-tale" grey hue.
Local discount shop had Tide F&G with ToD in those huge bottles. As one still had one and one/half jugs of normal Tide F&G still in stash wondered if there was any real difference between two. Comparing MSDS told tale, so that was that.
https://smartlabel.pg.com/en-us/00037000885825.html
Have huge amounts of soaps of all sorts in my laundry stash, so that's me sorted.
Cellulase is already present in other detergents in one's stash so there you are. [this post was last edited: 11/3/2024-01:07]
I'm talking about baking soda as a booster.. not by itself...
everything in that article suggested that it's bad to use baking soda and/or vinegar by themselves.
Mark, I do bekueve the concept is similar to using washing soda. Look that up and see what its uses are and how to use it.
Quite honestly one finds when using top shelf laundry detergents one doesn't really need to add any such "booster" product.
For stain removal on whites or colours when one is using liquid or other products that do not contain bleach (oxygen), then will add, otherwise find really isn't necessary messing about with a pinch of this or bit of that.
Miele Ultra White, Persil, and so forth do very well on their own. [this post was last edited: 11/3/2024-18:20]
Over the years I've read this vinegar debate over and over... and some will swear it's not bad for the washer while others say it will destroy it... Me? I've used it for 20 years in my washer and it hasn't harmed it.. I mean, Imagine if you put the max amount in... Say, you fill the bleach dispenser and the FS dispenser to max fill with vinegar...that vinegar is going to be so diluted to the point it probably won't even phase the washer... To be honest, I don't even know if the vingear is even doing anything...but I like using it better than FS...so I use it..... In my mind I'm not using it to necessarily "soften" the clothes... but more like a rinse agent
Acetic acid attacks rubber and some other polymers. Over time O-rings, seals and other components of washing machines (or dishwashers) made from same can be harmed or compromised.
https://mykin.com/rubber-chemical-resistance-chart
You don't often if at all see acetic acid used for laundry sours, descaling or other uses for acidic substances, and there are good reasons for this. Citric and other acids OTOH are chosen for good reasons.
No, 1/4 cup of 5% acetic acid (white vinegar) diluted into ten or more gallons of rinse water may or may not cause harm to washing machine. However that same amount sitting in dispenser drawer exposes seals and other bits made from polymers to full affect of said acid.
