macboy91si
SO!
I have FINALLY found a Speed Queen/Simplicity twin tub. After years and failed attempts I now have one. I'd be lying if I said I didn't get all spazzy and jittery about it. I could barely contain myself as I was on my way back from VA Sunday. The story goes that the machine was originally from Ontario and was taken down to Florida in a move. The machine was gong to be discarded and then ended up with a niece in VA where it remained until she got a full-size set. So this is actually a Canadian Simplicity. I removed the back panel once I got the machine home and the machine is in GREAT shape. The lady said she took good care of it and she was right. I cleaned the machine up a little and ran some water through it and everything checked out. Quiet, smooth and no rust. The ONLY thing "wrong" with the machine I discovered was the timer motor. It looks like a generic Mallory motor, so I took the timer motor from the gearbox but the motor won't start. The machine does still work though, 2 speeds and all.
The one really interesting thing about this machine is that it is actually a Simplicity brand, not a Speed Queen which makes it super rare. There are differences, big ones even though the machines appear to be the same. This machine is the same machine that our member Brad Ross has right down to the Devo lint filter, which is functional (but weird). Other differences are well, everything. The cabinet and agitator are almost the same, but the rest of the machine is almost completely different.
Differences:
<span style="font-size: large;">Pump:</span>
[COLOR=#000080; font-size: medium]SQ[/COLOR]: 2 pumps, one electric for the spinner, one mechanical pump for wash tub driven from wash belt with outlet in tub
[COLOR=#800000; background-color: #ffffff; font-size: medium]Simplicity[/COLOR]: 1 electric pump with an electric switch to toggle between and pinch valve for washer hose. 1 unified drain hose.
<span style="font-size: large;">Transmission/Motor:</span>
[COLOR=#000080; font-size: medium]SQ[/COLOR]: Pulley on side of transmission inline with pump & 1-speed WH motor mounted to lower frame sideways.
[COLOR=#800000; font-size: medium]Simplicity[/COLOR]: Pulley on top of transmission. 2-speed GE motor mounted upright and anchored to baseplate midway in chassis.
<span style="font-size: large;">Spinner:</span>
[COLOR=#000080; font-size: medium]SQ[/COLOR]: Direct drive spinner with galvanized, full-height outer tub. Spinner mounts to bottom of frame with drain outlet on side.
[COLOR=#800000; background-color: #ffffff; font-size: medium]Simplicity[/COLOR]: Direct drive spinner with shorter porcelain outer tub. Mounted to baseplate in chassis, motor exposed underneath.
<span style="font-size: large;">Chassis:</span>
[COLOR=#000080; font-size: medium]SQ[/COLOR]: Steel chassis with motor and spinner mounted to lower frame. Wash tub and transmission mounted to crossmember section.
[COLOR=#800000; background-color: #ffffff; font-size: medium]Simplicity[/COLOR]: Steel chassis with both tubs, motor and transmission mounted to a baseplate about 10" above the lower frame.
<span style="font-size: large;">Controls:</span>
[COLOR=#000080; font-size: medium]SQ[/COLOR]: 3 dials: (L to R) wash drain (mechanical linkage), mechanical wind-up washer timer w/bell, spinner pump/motor (controls elec. pump)
[COLOR=#800000; background-color: #ffffff; font-size: medium]Simplicity[/COLOR]: 2 dials: (L to R) drain control switch for both wash and spin tubs (off, spin, off, wash) also opens pinch valve, 2-sided electric wash timer w/ low and hi speed sections with 15 minute max wash time.
It's amazing how many differences there are for the "same" machine. Both the SQ and Simplicity machines are 1972, so I'm guessing these might actually be based on different Servis models or Simplicity just made their own alterations. With the SQ, you can really see that it is a Servis machine, the Simplicity is a more modern internal design though and I prefer it to the SQ, so I lucked out.
Who ever thought I'd not only find a SuperTwin, but a Simplicity branded one at that!
-Tim
(machine prior to cleanup)
