dried out rubber hoses
ladyk
Active member
Nov 22, 2014
42
Tacoma
I read about restoring dried out rubber by spraying it with silicone lubricant then sealing it up for a few days. Tried it. It works if the rubber hasn't cracked and too far gone. Soaked my bleach dispenser hose in silicone for 3 days. It softened up like new. Anyone else tried this?
For many years, whenever I've had a stiff hard hose I've reached for the silicone lube to massage it well.  This method has never failed to provide the desired satisfying results.
(Not ducking or running -- just saying)
I have bad luck with hard hoses, if I don't have anything close in the junk box ill take them to the local auto parts store and see if they can get a close match and retro fit it into the machine, I hate water leaks
"For many years, whenever I've had a stiff hard hose I've reached for the silicone lube to massage it well.  This method has never failed to provide the desired satisfying results."
Well Ralph, I'd definitely like to see a video of your technique.  I'm intrigued.
