Direct drive washers with very hard breaking
I also invented this process of putting a tiny dab of grease in the brake drum. I probably have done this at least 100 times it seems to work great, you can put a tiny bit of grease on the rollers, but that won’t have anything to do with the stopping to fast.
When the basket slams to a stop too fast, it could actually break the outer tub or knock the suspension out of kilter, and as Dave says in his fix for this problem, it can break or strip the basket drive block. It could not possibly however, break the drive coupling Between the motor and the transmission.
John
