Whirlpool Electric Dryer......model LE6150XSW1..serial MB4009745.....a nicely optioned machine...lint alert tone, drum light, all high heat, big knobs, cycle end buzzer...
Timer works...as in TimeDry......but not the Sensored Auto Dry cycles, dryer runs and heats, but timer never moves, it stays there with constant cycling of heat and air....
not a drum sensor model....would the sensor in the exhaust be bad....or is this a timer issue.......
have the same issue with a 1985 GE electric dryer.......
any ideas of what to check or could be causing the issue?...
