thomasortega
Guys a question for you, related to other model.
Washer-dryer combo.
9kg capacity wash
4kg capacity dry
Concept: Washer dryer combo made thinking about people that live in apartments that have no vent and no dryer hookups. It runs on whatever ordinary 110V power outlet without overloading circuits.
Max power: 1450W drying
Bell and Whistle: Removable drum that can be used as a dirty laundry basket, almost like the british Titan.
Electronic controls but analogic interface (dials only)
Slant front
Cons (and the question)
1.5 to 2 hours to dry a load. (dry condenser with a 10% vent)
10% of the air is vented but there is no venting ducts. It's a minimal and unnoticeable moisture coming through a gap on the door to the room where the dryer is.
It's not enough to heat up a small room in the summer and even in a confined space during the winter, it's impossible to see condensation on the walls.
Linting: Some lint is expelled during the drying cycle. It is unnoticed in a couple of cycles. But if you run several cycles without cleaning the room, then you can see some dust landing on furniture in the room.
Would that be a problem here in the US?
1) drying time?
2) moisture?
3) dust?
Notes to remember. It's a low end model, made to be affordable and cheap, an alternative for people that simply can't afford a washer and a dryer or simply don't have space or hookups for a full size pair and also can't afford a high end super capacity LG washer dryer and at the same time wants something better than the chinese ones (Magic chef, for example)
Average retail price between $500 and $600
is it worth to continue with the idea?
Washer-dryer combo.
9kg capacity wash
4kg capacity dry
Slant front
1) drying time?
2) moisture?
3) dust?
