Duet set are slowly starting to show signals of replacement
pierreandreply4
Sep 7, 2007
2,569
St-Bruno de montarville (province of quebec) canad
hello to all aw members,
My duet set are slowly starting to show signals of replacement after 8 years of use 2004 to 2011, time and the set i am planing to buy for my mom. And me if they show thats its time to replace them will be a rebadge whirlpool washer dryer set eather roper or estate the set in this picture to be precise and i have a few things that i would like to point if members have recomendations
1- no suggesting to go with a front load washer i went a good old fashion top load with agitator
2 no suggesting models with a lid lock as i went to be able to set the wash dial to a certain wash time.
Brands i am thinking of buying are
1-Inglis non lid lock model
2-estate (*rebadge whirlpool model in picture)
3- roper with matching dryer
4- huebesch model (ZWN432) with matching dryer if they are on sale and at a resnable price
5 amana washer dryer set
and also please note that every 2 months or twice a week i have to wash a pet bed and sometime may need to have clothes soak all night if stain thank you very much and all advice welcome.
Well not sure why you dont want another FL.
1.They take pet bedding more easily as you dont have to wrap it around an agitator.
2.FL's wash stains away without having to soak, pre treat and mess around if you use HOT/WARM cycles with POWDERED detergent which is better for machines. Dont see the point of having a washer if you have to soak things over night in gallons of water which is a huge waste.
3.TL's waste water and cost more to run.
4.A FL has a window so you can see without having the danger of bypassing lid switches.
5. modern fL's let you set times and can be more programmable to your needs than you may think.
well not for me the reason i am going back to a top load washer is because they are on a second floor and there is the matter that its a small space if 1 of my family members have to wake up at night and the main reason i am going back to a top load is because i can set the temp knob to cold water and leave it there and me i use liquid detergents and mostly wash in cold water the only time i use hot water is when i wash bedding and that vary from 1 a week to once every 4 weeks and second i for one thing do not need models with water heaters or fancy cycles like sanitize or vice versa and there is also the danger of my cats getting in the washer and have more control using a top load washer and top load washers do not waste water depending on where the water level is set. and if you look at this picture this is where my set is located and that space is very small and because the washer water pipe stick out behind the washer the washer is not = to the dryer position. and need to have the option to stop the washer if i have to go out of the house for a few hours as i do not went to have the washer running when i am out.
After 8 years why do these need to be replaced?  I've had my washer for close to 9 years and it works like new.... What replacement  signs are your units showing?  Maybe they could be repaired?  I dunno I look at washer/dryers on the market today and I can't find any that I would really want badly. Top or front.
I respect you opinion, but there are some facts you might know.
I always do cold washes in my washer and never had any problem with them... of course, door always ajar.
other reasons were posted above by aquarius1984.
Remember the new generation of american/canadian HE front loaders are much better than the first versions. They rinse MUCH better, save tousands of gallons of water every year and you can also pause the machine for long times (just hit the pause button) after some time the machine will shut off completelly. when you come back, just hit the start/pause button again to wake it up and resume the cycle from where it was.
Also, you can use both powders or liquids without having problems. BUT DON'T CLOSE THE DOOR COMPLETELLY BETWEEN WASH DAYS.
And the second floor issue... well... modern front loaders are now insignificant to the floor, they won't shake your house at all.
Watch cleamteamofNY's videos. He has an Electrolux Wavetouch. Maybe your opinions can change.
More than that, the spin speeds can be much higher, saving you lots of time and money in the dryer and they clean much better than front loaders because as is uses much less water, the detergent solution is more concentrated and mechanical action happens during all the time to 100% of the load, while in a top loader it deppends on rollover action.
Plus a pet bed in a top loader.. one side of it would be damaged (excess of rubbing against the agitator), maybe it would float and some parts won't wash and it's more prone to spin with a huge unbalance that could damage the machine or even make it walk.
$0,02
well its the age for 1 thing and second there is the reason that for me in the space the washer dryer is the door of a front loader is in the way and there is the fact that for me du to my size its not practical for loading for 1 thing and the second thing thats also making me chose to go back to a top loading washer is i know that my clothes won't come out smelling like perfume as i am very sensitive to strong perfume smell if a sent is to strong i heart sneeze or get a headheach because of the detergent smell if they have a smell thats to strong and the pet bed that i wash is like a pillow case.
and also the main reason i am going back to a top load washer is for these reason
1- a front load washer no longer fits my needs when i wash
2- a top load hides the plumbing pipes see my picture in my post number 548302 reply number 2
3 and finaly i do not need all these fancy cycles like sanitize allergen or a heater in my washer and there is the reason that for dose wondering why i prefer to op for a direct replacement rather than a repair is the last daily driver i had witch was a top load inglis superb 2 washer (whirlpool) had 2 repairs 1 in 1996 a motor change and around the year 2004 a few months before we had to replace it since it was already at the end of its life use a timer replacement and then by september it was the agitator so it was replace with the model in my post # 548302 i tryed but i never like it when it was replace i was looking at the price for a top load washer in 2004 and like i explain sometime i may have to soak some clothe that needs to be soak all night 24 hours and also the main reason i am going back to a top load model is because for me its easyer loading and unloading a top load washer than a front load model.
Ok... and can't you find in Canada any H-axis top loader? They save lots of space and still wash huge loads spending less water.
about the dependability, they will also last the same. If you want an excellent machine to last much more than moderns, you should get a vintage model
Not sure about the models you have there but... Probably the top loaders also have electronic boards and won't be the same as your previous top loader. If you're really lucky, it will last for 5 years.
i rather buy new and for me the rebadge estate or roper brand rebadge whirlpools tends to fit my needs and i can get some conventinel top load that are set for low water usage like the amana brand washer dryer this set to be precise and here in canada the brand you are mententing i do not think they exist as well
i am waiting until the ones i have breaks completly i am only in planining stage for when i do a spending budget witch might be in 2012 or if we decide to do some work in the bathroom but thank you for all the info but might first choice might be the estate set because my dryer is clearly startin g to show signs of failure like not drying proper so it might be soon i will keep everyone posted lol
its way to hard to clean the way its set and i do not have the requiered tools i might try using the time drye cycle that will disable the drying sensor since i always use the auto dry cycle and i think what shorten my dryer lifetime use is a couple of summers back that was around 2005 2006 there was a bird that entered the dryer vent and went inside my dryer so i think it kind of shorten the lifetime use of the dryer.
I'm here wondering about the drying times...
How fast is the spin on these top loaders?
Maybe you could consider a spin dryer too. They are cheap, very useful as they can remove much more water from a load before you put it in the dryer and they are also very small so won't take space.
Think about it. I don't know what models are available in Canada or even if they are available, but i think they could help a lot.
These spin dryers are also very economical (only a few watts), very simple and easy to use and the load is ready in 2 or 3 minutes.
Choose wisely
Avoid any TL WP made set that does not have a fabric softner added switch. These machines only do a low water rinse which is the equivalent of a rinse in a severly overloaded machine(not very thorough and hard on clothes). The FS switch makes the machine rinse at the same level as wash. The Speed Queen machine is your best bet but you will have to adjust the water level switch as the Eco-Nazis and Green Police have regulated reasonable water out of them as well.
