pierreandreply4
here is the reason why i am chosing to go back to a top load
Here is the reason why i am going back to a good old fashion top load washer:
Top-loading washers
• Removes more dirt on average in a normal cycle front load washer.
• Met generally less time to complete a normal cycle that front-loading washer.
• Rise in average a little more than a gentle cycle front load washer.
• Is generally less noise than a front-loading washer.
• is more ergonomic, due primarily to the position of openness and lack of clean seal.
• Takes up less space generally a deep front-loading washer.
In short ...
Overall, the efficient top-loading washers that Protect You have tested provided better performance than the front-loading machines.
They are the best choice if you are not or little delicate cycle.
and its very rare that i use the delicate gentle cycle i only use this cycle for washing curtains
Top-loading washers
In short ...
