Early Europeanen automatic front loading machines
2 x portholes
Do you mean door seals ?
The bolt down machines just have 2 rubber seals that press together when the door is closed as the tub doesn't move you do not need a moving seal.
Non bolt down that have springs and tensioners need a door boot to seal the moving tub to the stationary one this boot moves with the tub.
Hope this helps ?
Also the older machines had a soap hopper on the top of the cabinet to allow you to add powder etc these then moved on to become soap drawers in newer machines. Although some newer machines which are commercial laundry items they still had soap hoppers.
Hey everyone! Just found this thread, very interesting info.
Here I have this really rare General Electric front loader. Pretty sure it was made in Europe, but i couldn't find any information about this one.
Anything you might know will help!
Upo
Here are the pictures from the inside and from below where you can see the mechanics and the picture from below the machine has a big concrete casting and it is very heavy I own this machine this machine was sold under the name upo pesukarhu
Upo washing machine
@ foraloysius
" Letting a machine run like that without bolting it to the floor should be a deadly sin!"
Hi Louis, I have to correct you in that. Those old Indesit machines were not supposed to be bolted at all. They where made with a tub fixed to the outer casing and they had no suspension. They were made instand on casters on the bottom.
They were meant to "float" on the flor during the spin cycle like for example the old legendary small Rex toploader P5 (or Naonis) or the Eudora washers.
Washing machine
Does anyone know about those Wyss Mirella washing machines, papa had such a Wyss Mirella wascator schulthess or Osby Swedish washing machine in the barn, I'm interested in finding out about that Wyss Mirella, there hasn't been any information, I'd be interested to see the cover plate removed from the Wyss Mirella washing machine, as I remember, it has relays and that program selector, unfortunately the barn doesn't have these anymore the memories are that Wyss Mirella universal 61 is familiar in structure, I remember it and that schulthess
Washing machine
Answers you need
Reply 40: The hole in the front is for adding detergent directly into the drum. So you must not open the door after the prewash is done, and leave it closed for safety. Since when this machine was inventet in 1951 there was no low sudding detergent availalbe. So when you do laundry you had to ad detergent carefulley, so the foam dosent flow over.
The hole in the back is for "Spülmittel" here an old package on ebay: https://www.ebay.de/itm/114356751390
This is a combination of, i would say, bleach and watersoftener, make stains from red wins etc, and yellowing go away and make rinse water soft like rain water.
skip to 4:25 to see how the washer is used
When boiling clothes in a tub, you may take Henko for soaking over night, Persil for boiling and washing, and Sil for the first hot rinse.
When the machine came on market the housewife would have done the laundry like she was used to. The Spülmittel was added to the tub after the prewash is done.
Here how the filling works:
The back hole is fittet to a tub. Water from watervalfe flows into this tub and fills it up until it is full and flows over in the next tub where the drum is. The flotor is conectet with the tub and when the waterlevel raises in the tub, it flots up switch of the cuerrent to the watervalfe and switch on the timer, heater, Motor etc. The tub with the Spülmittel has a heater, too. During the washing cycle the water will timed heatet up until it is hot. If you set the timer for shorter wash, lower tempearture for the clothes and the tub with the Spülmittel will be the result. (See the different starts in the cycle in the video.)
Because of the detergent you had to rinse the clothes in the first rise with hot water, in the second with warm water an final in cold water.
Since the maufactures of detergent jump on the new technology, the next generation of constructa does all rinses cold, saving lots of energy.
The double doors of the Bauknecht an AEG etc. was the result of invention of the not boltet down machines from construca. Makes it possible to install the washer easily in a flat or appartment. Constructa has inventet the door seal and put a patent on it. If the other manufacturers would build their machines with that seal, they must pay for it until the patent run out, and now the most washers ar build like today kown.
Thanks for sharing my Bauknecht WA35 washer.
Happy new year, Technowasher
