captainmoody
- Joined
- May 22, 2006
- Messages
- 348
This one came from the original owners basement. It was sitting next to the one that replaced it, a Green 60's Kenmore! which was sitting next to the empty spot where I was told there was a 90's Kenmore! (it had been sold)
I did NOT plug it in, but did check the underneath of the washer, and after cleaning off some filthy cobwebs it looks pretty clean, and has little to no rust on the bottom edges.
I turned the pulley by hand and the trans appears to be free as well as the motor, but the belt just slides across the water pump pully, and it doesn't turn. So that will need some work to free up. This washer has been unused for about 40 years so i'm sure it will need a good checking out before use.
Anyhow, I thought someone who is more into the early Whirlpool/Kenmore machines would appreciate this. I am more into late 50's 60's stuff.
So, If anyone is interested, I might be willing to trade for a Frigidaire washer from the 60's or something TOL from that era working or not.
Oh, The model is 110-93544 and the Serial is 28433 So is it a '49 or a '52? (I'm not sure from the serial#)
