Easy As Pipe -- Antique Cast Iron Sconce Installed!
Step One
After removing the existing fixture, it was time to position the flange inside the box (see original thread for discussion around this).  I was limited by the house wiring coming out at the top, but the flange ended up in a viable spot.
This shot was taken after it was fastened into position.  I was surprised at how easily this was accomplished.  Two screws were plenty.
The only thing left at this point was to spin the fixture into place.
A Closer View
A bit of detail.  The canopy turned out more glossy, but I think it will fade with time.
It Works!
Lit up.  You can't really tell there's a 60 watt amber bulb in there, but I'm looking forward to this evening when I can check how well it lights the entry.
I'm going to wait to look for touch-up paint for the stucco.  I'll  leave the decrepit gothic look until after Halloween.
Thats super nice.....I know you put an amber bulb in....but wonder if theres one that would flicker like a flame....
I do have a friend -- from Brooklyn -- who has an outfit and has dressed up like Lady Liberty before.  I'm not so sure she'd want to spend Halloween night out on the porch, though.
Martin, if they made flickering types in high enough wattage, I'd consider it for Halloween night.  The current amber bulb is barely adequate for lighting the steps up to the porch and the flickering types I've seen emit very low light.
Here's a shot without the flash.  It's difficult to get the exposure right when it's dark out, but you can make out the shape of the globe.
That's a fun and decorative fixture, and it looks appropriate with the vintage of the house.
" . . . a cool piece of history."
I wish I knew more about the history of this piece.  It was the last thing I'd ever expect to find at the little old ladies-run thrift shop I visit a time or two a month.
Thanks for the compliments on the house.  It needs work both inside and out, and keeping up appearances doesn't come cheap.  The original plan was to buy out my sister, spruce the place up, complete the parent-to-child transfer of Proposition 13 property tax rate, and put it on the market.  The only problem was, this all started happening in the summer of 2008, right when the bottom fell out of the real estate market, so here we sit.
At this point, I dread the thought of moving.  Since Dave had his stroke, every aspect of the job falls on my shoulders, and I did most of the heavy lifting last time because of his bad back, even though we hired movers for the bulk of the work.  Much as I'd like to go back to a low slung MCM home that's more my style and preference, and as much as a single story living space would be better for Dave, it's a decision that needs very careful consideration.  We can only move once and still retain the Prop 13 assessment, which offers a huge savings in property taxes.
I'm not ready to go house hunting just yet, and the market needs to recover further before it would make sense (at this point we're back where we were in 2008 where equity is concerned), so for now I'm trying to make the best of the situation by doing fun projects along with select improvements that make this home more livable while we're here.
This is also known as the "gay ZIP Code" in town, and we have a number of couples and single men in the vicinity, including one couple whose property borders ours.  That's another reason I'm in no hurry to move.
Very nice, Ralph. You did an excellent job. And the paint finish on the torch body is excellent.
I'm sure you're planning on caulking the join between the torch body and the stucco. Might I suggest a new product that DAP recommended to seal the new gutters for my carport? It's called DAP 3.0, and comes in a few different flavors - but the one for doors, windows, and siding is what you want. The DAP tech phone support representative assured me that it beats out all their own products as well as those of competitors. It's quick drying, and can be painted over in 30 minutes. It also stays flexible, and unlike silicone caulks, is 100% waterproof, and doesn't shrink or crack. I took extra time to research caulks because the gutter location is such that it will be a PITA to go back and fix it if the caulking fails.
Right now DAP 3.0 only comes in clear and white, but with a dab of paint nobody will notice for your application.
Also, regarding night shots... I have some older cameras with "night fill" settings for the flash, but I notice that more recent, supposedly better, cameras don't have that setting. I'm not sure why.
As far as the flicker bulb goes... perhaps it's just a matter of time before some bright youngster at GE or other light bulb company figures there may be a demand for LED powered realistically flickering accent light bulbs of sufficient wattage. If they really wanted to get fancy, they could roll a small LED screen into a tube and project the image of a flickering gas light onto it from within.
Great Light
Ihave the same type of wire all over my house,itwas built in 1938,its so thick.Its always nice to see someone put up vintage lighting on older homes. Yours is really beautiful.I changed mine back to close to what my house had.Someone had put up some cheap porch lights,I hated them and finally at the Restore shop I found 2 decent lamps and repainted them and put them up,what a difference. My yard lamp is an original bronze ships light,the lense inside of it has turned almost purple inside of it with age. I put a small halogen outside bulb inside of it and it seems to really light up the front yard. Thanks Bobby
