aviator74
Member
Hello.
I have gotten help on my Eatons Viking (Filter Flo) washer in the past, and I'm hoping for some on my dryer. The dryer is an early 80's vintage (I think), GE, private labeled for T. Eatons Co. in Canada. A couple days ago it stopped running, in that it has power and hums when the start switch is activated, but it will not turn. I suspected the issue was with the motor run windings so I opened the machine up and found the motor shaft will rotate about 1/4 inch maximum in either direction. It feels and sounds like the internal mechanism is running into something that stops rotation. There wasn't anything obstructing the blower fan, and the hum indicates to me that the motor is getting power. I am going to try to get some oil into the bearings, as I assume that after almost 40 years, they may be an issue. I may need to locate another motor and I am hoping for help. The motor is stamped with a Camco part number 111D222(0?)P4 4J702DX 6 but I can't find any kind of crossover. would anyone have any information or suggestions?
