So I was wondering once more...
How effective are pre-rinses in DW?
So how much work do main washes have to actually do?
I was thinking as my Miele seems to have exactly one kind of pre-wash for any occasion: 20min cold.
And having added some dishes into the main wash the water seemed rather clean.
Have seen many pre-washes far more intensive than this (heated and longer) and the Mieles results are good already.
I mean I did switch to using some detergent in the pre-wash, but even without not much can be left for the main wash.
Unless something is actually burned on, with a total wash time of an hour, I can't really see how anything beyond a quick hot-ish wash can be needed.
Temperature and detergent are mainly needed for degreasing and some time is needed to rehydrate dried on stuff.
Unless burned on, it really shouldn't be hard to build a quick effective cycle.
Actually, over here, 90min seem to give the best balance of efficency and results.
90min gives you 10min for a cold pre-rinse, a quick main wash up to 50-65C (120-150F), a rinse and still about 30-45min for final rinse and dry.
Usually heating rates are about 2C per min (that is 4F) or higher and with a 20C fill (like 60F or so) you only need 15-25min to reach top temp.
Usage data for such cycles often go no higher than 15l (that is like 5gal or so) and 1.2kWh.
With a hot fill and less heating power that should still - more or less - adf up the same.
Maybe some higher usage (like 6gal or so) and to split the one pre-wash into 2 shorter once to get more of a hot water line purge effect.
Heck, maybe even do that sensor based (cold first fill means 2 pre washes, warm first fill means 1 pre-wash).
If you don't mind some more time (2h) a 4gal cycle with extended heating in the main wash should be doable and be verry competitive with other machines.
Anyway, wanted to know your opinions.
Maybe share you post-pre-wash pictures.
Happy to hear from yall!
