Eggs easy peel
mattl
Sep 17, 2007
6,331
Flushing, MI
Don't know if anyone else here listens to science Friday on NPR, but they did a segment on hard boiling fresh eggs. As most of us know unless the eggs are a month old they are close to impossible to peel. Well, it turns out those with egg steamers have the right idea, steam the fresh eggs.
The guest said he found that bringing 1/4" of water to a boil then placing the eggs in the pot for 12 minutes works very well. I tried it today with week old eggs and it works! Eggs peeled easily. The yolks are not as nice as when I do Martha's method, place eggs in water, bring to hard simmer, turn off heat wait 12 minutes and then into an ice bath. The yolks in the batch I did today had a slight bit of green, never had that using the regular method, but they are certainly acceptable, especially for fresh eggs.
I use a Black and Decker veggie steamer to cook the eggs, and then roll them to peel....
fool proof with the timer.......
at the same time, in a second steamer, I will steam potatos, once blanched in ice water, the skins peel off instantly.......add a few ingredients, and I got potato salad in a jiffy......
Boiled EGGS!
I just about would rather have a root canal than smell a boiled egg!! I will not use them !!!It stems from my Mothers love of them, she put them in everything, I wouldn't eat potato salad until I was about grown because of those chunks of boiled egg!!!LOL
I saw on a video recently that if you put a little bit of water in a drinking glass, drop the hard boiled egg into it and then cover and shake the glass a little vigorously, the peel cracks all over the egg. The little bit of water you use enables the shell to slip off easily.
They said in the video that this also works for a couple of eggs at a time as well.
It's on YT under "How to Quickly Peel a Boiled Egg in a Glass of Water"
I'll have to try these methods; thanks for posting them, guys.
I put chopped hard-boiled eggs in deli macaroni and potato salads, as well as my favorite scalloped potatoes recipe---and I like egg salad sandwiches and deviled eggs. In other words, I boil eggs quite often.
After cooking, I pour out almost all the water, then shake the saucepan around vigorously so the eggs crack. Then I fill the pan with cold water while tapping each egg on the side of the pan, then peeling them under the running water. Works 95% of the time.
Steaming works great
For small batches 7 or less I have an eggcelent egg cooker.  Perfect everytime and peels easily.
Now for the three dozen I just cooked off to dye tonight, I used the stock pot on the stove, most of those will be deviled by tomorrow, about a dozen is reserved to pickle.  My daughter always keeps a dozen to Play with as she plays re-hiding and finding them for about a week, then they go to the compost bin usually.
I just picked up an Oster egg cooker last week.  It appears to have been barely or perhaps never used.
I like the look of my Sunbeam better, but I can't seem to get the hang of that one.  If the Oster provides good results, I'll be using that one instead.  I like that it has a teflon poacher and clear glass lid to see how things are progressing.
It seems that if you want to hard boil a dozen eggs, you'll find over a dozen "perfect" ways to do it.  I've done it a couple of different ways, dropping the eggs into boiling water, or starting them in cold water and bringing them to a low boil, then simmering just enough so that bubbles break the surface.  The main thing is not to overcook the eggs, which results in the grayness around the yolks.
Peeling the eggs is easiest when they're warm.  It's when they've cooled that the peeling tricks are most welcome.
Ralph,
<span style="font-family: 'book antiqua', palatino; font-size: 12pt;">At first I wasn't too keen on my Oster egg cooker either as I got it as part of a box lot at an estate auction, but I love it now.  I do however spray the poacher sections with a light coating of olive oil before adding the eggs, just as a precaution.  I get perfect results every time with it.  And, I agree about the clear cover and being able to keep an eye on what's going on while it's in operation.</span>
Clear Glass Lid
News flash:  If you're poaching eggs, the cooking process doesn't include a shell.
My Sunbeam does have the measuring lid.  What it doesn't seem to have is correct timing to correspond with the measurements.  I've experimented with the adjusting screw on the bottom but it still seems to either under-cook or over-cook.  I've also tried using more or less water to influence the outcome, with mixed results.  I get it to where it will poach nicely, but then hard-cooked will end up under-done.
At this point, I'd rather have eggs the way I like them than keep fooling with the Sunbeam and dealing with eggs that don't turn out as intended.
Ralph,
What I like about the Oster version is that you can control the doneness of the eggs simply by the amount of water you use.  No having to adjust the heating element.
Tim, I thought the same was true for the Sunbeam, but I can't seem to find the right amount of water for the desired results.
I'm hoping for better outcomes with the Oster.
So Hans, I guess that means you're not going to fix me any good ol' southern style deviled eggs when I come visit again?
I use the spike in the center of the rack from my Sunbeam egg cooker to pierce the wide end of each egg where the air bubble is and rack them narrow end down for cooking. It greatly reduces breakage during cooking. I cool them with ice after cooking and refrigerate in Tupperware to contain the stink. To peel, I hit the wide end lightly enough to just crack it then run very hot (Instant Hot) water over that end of the egg for maybe 4 or 5 seconds. After that, the shell almost detaches from the egg. If you don't have an Instant Hot, you can heat 1/4 to 1/2 cup of water to boiling in the microwave and dip the wide end of the egg into it and you will have the same success.
