Consider this!
Gentleness - I think the gentleness test is not really indicative of anything much and ultimately more valuable for marketing than real life experience. The cloth they use to test for this is just loose threads woven into fabric without stitching. Of course the more vigorous agitator action and water currents of a top loader's regular cycle will show up wear instantly. Does that mean I spend my life in threadbare duds - No. If you took the same piece of cloth and simply hung it out in a stiff breeze for a few hours there'd be noticable fraying around the edges too. If they rewashed the same piece of material two or three times in a front loader they would end up with the same level of wear as well. What if, instead of putting the test material through a regular cycle in a top loader, they only used the gently cycle, would they get the same sort of comparisons? Would you guys wash your silks, woolies and other dainties with your ruggers, duffle bags and studded leathers on the heavy duty cycle? BAGS NOT!
Youse all know that regular clothes are not usually meant to fray at the edges, unless they are junk, and threads don't pull apart from the middle, unless there's already damage. Mixing loose hooks, open zippers and other items that can catch and pull threads can cause damage in any kind of washer. Need I go on?
I've been washing clothes since I was nine years old too and I'm now 45 - so that gives me six more years of experience than someone else here. I've used horizontal axis top and front loaders, wringer washers, impeller washers, standard top loaders, scrubbing boards, laundry paddles, rocks, bricks, my bare hands and anything inbetween. My verdict - 99% of wear and damage to clothes occurs on the body, when bugs get at them, or when I've hit them too hard with a brick (or other really bad laundry practices). So I don't worry too much about the 1% that is the CR test on 'gentleness.'
Lots of newer front loaders wash clothes for longer in less water and they don't rinse too well - as already state in this thread and confirmed by latest CR tests. This means that there is more friction in higher chemical concentration over longer time frame, with higher chemical residue in fabric after cycle completion. The result of this may not become immediately apparent, but it ultimately means more electricity use, higher chemical and salt concentrations in grey water, as well as fabrics, which will lead to itchy skin, crappy clothes and not so happy environment. Now compare this to saving of and extracting a little more water to save on utilities - am I being too sceptical?
Reduced detergent use - hm, not so sure about that one either. My guess is that would depend on the formulation used. With products like SA8 (usable in all types of washers) I couldn't agree more. Though the regular supermarket stuff all seems to be packaged in the same quantities and costs about the same, regardless of whether its for top or front loaders. The scoops in front loader detergent boxes are as big as those in the top loader boxes. Surely households using same capacity top and front loaders with similar laundry patterns/habits would more likely spend and use about the same quantitities of detergent. Detergent companies depend on product turnover.
Anyway, let me know what you think.
Cheers
rapunzel
Cheers
rapunzel
