Euro wash times vs. US wash times...
pulsator
Bronze Member
Jun 30, 2002
2,375
Saint Joseph, MI
How long does the wash cycle usually take on Euro washers? I've been thinking that the reason I'm having such trouble with the Ariel Excel Gel and Persil may be related to the fact that my Miele W1215 only washes for 27 minutes on the Normal cycle with a full load and 43 minutes on the whites cycle with a full load. My whites loads are usually on the small side and so the machine cuts the wash time to 36 minutes! Is that drastically different from Euro wash times? I've been using the extended option and am wondering what else I can do? Is there a way to change the programming to wash using Euro cycles? Because from my understanding, Euro wash times seems to be a LOT longer than US wash times!
euro wash times
on my miele the cottons wash at 60 is 1hr49 and the minimum iron cycle is 1.19. have tried Arieal gel and think its ok but I do prefer presil non bio liqui gel, better bubbles!
Normal wash for me is 1h50m. Actual washing is ca. 1h10m. Rest is for rinsing and spinning. Delicate wash is 45m. Actual washing ca. 25 m. Rest rinsing and spinning. My old Miele had about the same durations. For normal wash the first 10m. or so are cold, then heating starts. With delicate wash heating starts immediately.
Euro washtimes are way too long!!
I hate european washers, they seem to wash endless. My AEG needs up to 2:23 h for a boilwash and 30° normal cycle needs 1:54h! mainwash is about 1 hour.
But I prefer using the short wash cycle in order to save time and to protect and care my washing. 30 min for mainwash seems enough for my laundry and 2 rinses seem to be sufficient to get rid of the suds. I like using Ariel coz it actaully removes stains best.
I could be wrong but..........
My understanding of US spec washers vs. European spec washers and their cycle times is.........
Here in the US we have externally heated water supplies (water heaters) and washers have both HOT and COLD water supply lines connected to them, thus, get the desired water tempature WHEN the washer fills.
From what I have seen in Germany, Italy and Hong Kong, the Euro spec washers have only a COLD water supply line connected to them and use an internal heater to, yes you guessed it, heat the water for anything beyond cold.
Obviously it takes TIME to heat the water (and the wet cloths) from cold to the desired degree of hot-ness (hows that for a word? LOL) for the chosen wash cycle.
Time required to heat water = longer cycle times.
Are you talking about the wash time or the whole cycle time, including rinses and spin ?
Is it a cold fill machine ?
My Miele is set to 45 min wash time on a regular cotton cycle and if the extended button is pressed it is 75 min. A whole cycle can easily take 2 hours to complete.
I remember your socks did not come clean in the Ariel Excel thread. May I ask what type of Persil gives you poor results, German or UK one, powder or liquid ?
A suggestion.....
Jamie
Your Miele is 220V and has a heater right??
Id suggest putting a Y adaptor on the cold feed and trying it as cold fill only. Euro detergent is designed with an enzyme stage thats designed to work as the water heats- putting hot water in at this stage wont help things.
Using cold will probably extend the wash times as well.
If you were feeling brave I dont know if Miele US would be prepared to give it a Euro PC update???
Seamus
The main wash on our Electrolux takes approx.
25 min. for a cold quick wash
35 min. for a 104°F quick wash
40 min. for a 140°F quick wash
70 min. for a 104/140°F regular wash
100 min. for a 140° wash on the energy saving cycle
Rinsing & spinning adds another 30 to 40 minutes.
Have tried the Excel stuff and am not too pleased, either.
Alex
Wash times on "European" washing machines reflect several factors.
First, time is allowed to heat water (tap cold or warm) to whatever temperature desired. Some Euro front loaders have their thermostats routed through the timer, much like dishwashers and will hold the heating portion of the cycle untilt he proper temp is reached, (however long that may take). Other machines simply are programmed to allow certain time parameters for heating water, once that time is up machine will advance to main washing portion of the cycle, regardless of water temperature. However most if not all of the these machines will continue to heat the water until it reaches the set temp. However should the wash cycle time out before the temp is reached, then that is the end of that.
To be fair on 220v or even 400v power, heating 8 to 10 gallons of water from 80F to 140F or even 200F isn't going to take that much time. With American front loaders running on 120F, there probably are going to be some problems.
Long wash times also are a reflecton of European detergents, which combine oxygen bleaches, and perhaps enzymes.
The cold or cool water start, prevents protien stains from being set.
Warm water period is to activate enzymes, which worked best at 100F to 120F
Hot to boiling wash period was to give the oxgyen bleach proper temperature and time to work.
Being as all this may, modern detergents on Europe are more and more designed to work in "quick cycle" wash times. This is due mainly to advances in detergent chemistry which allow the above chemicals to work in cold, cool and warm water. Thus cleaning takes place rather quickly, instead of a long drawn out process.
There are enzymes that will work in cold and warm water.
Activated oxygen bleaches or percarbonate bleach (works in cold water, unlike perborate which needs hot water), mean bleaching action can start sooner and is complete even in warm water.
Your problems with Ariel and Persil may be related to your water quality and types of soil, and not merely a short cycle problem
Try adding some STPP along with your Persil. In my Miele normally use 2 tablespoons of Persil "Sensitive" along with 2 teaspoons to one tablespoon of STPP, for a full (5kg) wash load, and find everything comes out great. If you are in the habit of wearing socks around the home as "slippers", then you have ground in dirt, which will take some work to shift even under the best situations. However phosphates are great at removing clay based soils from laundry.
L.
Try Normal + Extended
Jamie,
if it isn't enough, use the soak option too (soak water is used for main wash too).
In EU mieles "extended" is the default setting, we have "short" option . 4 or 5 years ago the W2000 series (the MrBoilwash one, I guess) had default short washing times, then miele went back on tradition
Your W1215 is a specific model for US market so it has US timings as default setting BUT ... as my W844 has default EU settings, yet entering in service mode it is possible to switch to US/AU/Swedish programme timings, MAYBE your machine can do it too. Look for service manual
I bet your "sensitive" option can be customized to all the 4 ways as the EU equivalent "water plus" option
Carlo
http://popup/controlPanel.asp?model=46&ww=800&wh=315
Long wash times - a recent phenomenon
European h-axis washers have very long wash cycles, largely dictated by the requirements to meet EU performance ratings - the AAA rating being the nominal 'best'.
Before the advent of EU ratings, h-axis washers in Ireland and the UK had significantly shorter cycles, partly because hot and cold fill was common (only disappearing here in the last few years), and more significantly because the machines used much more water than is deemed acceptable now. Lower water levels require more mechanical action to remove dirt, so tumbling time is increased. A by-product is that the action is far rougher - formerly the tumbling action was cushioned by the water in the tub (and the turbulence in the water would help the washing action), now the laundry is effectively thrown against the wall of the wash-drum - rather like beating the laundry against a rock (albeit a stainless steel one - progress eh?). US and AU readers should probably read through the ad-men propaganda that describe the 'new' tumbling action HE washers as gentler on laundry that top-loaders - I doubt there is very much in it in the long term.
The cold-fill issue is a bit misleading - someone else has noted that the 14-20 litres of water in the average wash component of a cycle wouldn't take too long to raise with a 2.5kW heater on 220v. The 'washing powders perform better' stuff is a bit of ad-men work too - UK detergents are for all intents and purpose 'universal' - with different ingredients that are effective at different temperatures - enzymes at cool and warm temperatures and bleaches at higher temperatures. Organic stains set of course at high temps, but wash out in cool and warm water.
My Bosch FL is sold with claimed total cycles times a few minutes proud of an hour at 40 (US warm) and 60 (US hot) on a cotton cycle - not bad for a front loader, and ostensibly far better than much of the competition. The rub is that none of the basic default cycles is actually A rated!! To achieve the mythical A for performance, one has to select a 'Wash Plus' option which surprise, surprise doubles the total cycle time. Bosch users will know that there is a default 60 stains cycle - which takes over two hours. In addition the rinsing is poor even with the extra water option - especially if liquid detergents are used. Two hours might not seem excessive if one has one load to complete and other things to get on with - after all the washer is automatic, but when one has a back-log if is a total irritation - four loads takes longer than the average working day. I find this totally infuriating when one thinks that the now abandoned Hotpoint V-axis Top Loader would do a 60 cycle in about 40 minutes, with outstanding results (and that was in spite of an EU G rating). In other words, where an EU h-axis machine would take 8 hours for four loads, an American TL would have that done in about an hour - progress indeed...
So the laudable aims of conservation have given us washers that take much longer to complete their cycles. The Cold-Fill only business is now subject to the onset of a somewhat ironic back-lash, as people with green-sourced hot-water (from solar/geo-thermal etc) are wondering why they can't use this in the washers. I predict a full-circle point where we see manufacturers selling us Hot and Cold fill machines as the latest new eco-feature. Indeed I recently read an article in a 'How to be Green' directory which gave as advice point 3 'connect the washer to fill with hot water which will be more economical than heating it in the machine'....
Incidentally have any US readers tried the new Maytag Bravos with built-in heater? These machines seem like a great idea (and look cool) - I wish Maytag would bring them to the UK...I'd buy one
http://maytag.com/catalog/product.jsp?src=Washers&cat=18&prod=1861
One reason I love my vintage Miele is that it has a mechanical timer. Can adapt any cycle to suit my needs, rather than allowing the machine to decide. This very handy when one has lots of laundry to get done, and not lots of time.
Cold Fills are one of the biggest "lies" being thrown around these days for front loaders. The concept does make sense in many parts of Europe, the UK and other parts of the world where central hot water heaters are unknown. Many French kitchens for instance still have a small on demand hot water heater in the kitchen near the tap, another in the bathroom and that is it. So if the washing machine is no where near either, it makes sense to let it take in cold water and get on with heating. However if one has a central source of hot water, and that water is going to be heated regardless, the savings by cold filling aren't what they are cracked up to be.
Consider many European front loaders do not heat water at full blast, but rather gradually, supposedly this is better for textiles. Well it also adds time to the cycle.
"I predict a full-circle point where we see manufacturers selling us Hot and Cold fill machines as the latest new eco-feature."
It already happened! Both Bosch/Siemens and Miele have released "Eco" washing machines on the German market which have a hot/cold fill.
Hints to confirm what Launderess and Liberator wrote
#The lie "cold fill = energy saving" : hot & cold fill EU FL#
- Here in Italy Zerowatt, Philco, Zanussi and even Candy made some washers with double fill to save energy
-Miele has ever suggested a double fill model for EU households who have solar/gaz/heat pump HW. In the last decade they are W913-W929-W3525-W3841. They can operate with hot/cold fill or rain/potable fill or well/potable fill. By the way, washing times are the same of the cold-fill-only models
-Now Zanussi too does it again. As here solar heated water is getting common, they sell SUNNY, a double fill machine. Very interesting feature : one can switch to cold fill only simply by pressing a button - see link - sorry, it's in italian... ask and i'll translate :)
#Longer times have to do with lower water levels too#
-In the early 70ies miele claimed to run the whole boilwash cycle by 70 minutes (higher levels & monster internal heaters)
- My 80ies W780 has 15 min prewash + 45 min wash whatever temp you choose vs the 10 min preW + 75 min W on the W844
- Consider the PW5065 Little Giant. It has the same drum size (53 litres) as EU household models BUT it takes only 49 mins to run a 60°C/140°F whole cycle. Ok, it's double fill and it has a powerful internal heaters. Just have a look on its user manual : programme sequence shows that certain "commercial" programmes (towelling, kitchen linen,table linen ...) run with higher water levels than the standard cotton programme. This happens to have both wash performance & short times
http://www.rex.it/sunny/index.htm?utm_source=hp&utm_medium=sta&utm_campaign=site_sunny_it
Heating in UK Front Loaders
Hi David liberator1509,
Your post is spot on and I enjoyed reading it.
I just want to add something as an Engineer (Now retired due to ill health).
I can assure you that 99% of Front loaders sold in the UK do heat to the selected water temperature. There is an exception though on the 95°C cycles the maximum temp reached is usually 85°C, this is by design as most washers are fitted with 85°C thermostats. The new electronic sensor designs are of course linked to Microprocessor Controls which are programmed to cut the heater at 85°C.
The only washers I recall that had 95°C stats were the old Philco Bendix machines, models 7142a,7147, 7147a, 7147b, 7147pb, the later 7148, 7168 and 71258 had 85°C stats. Like most UK Front Loaders the thermostats were linked to the timer; with the timer in the heat position the wash rhythm was reduced and the timer was locked until the temperature was reached, when the thermostat closed the timer was able to advance through the cycle.
There were some less common machines that used a much less accurate timed heating system, this system was usually found on bottom end machines.
David
At least you're not alone, Pulsator
Have received an email from a friend of mine who is using Ariel Excel in his Miele 1986 and reported having the same problem with white socks.
I generally wonder what kind of cleaning one can expect from a liquid? Maybe I'll sacrifice a white towel of mine and just try it out...
Alex
I don't know how it worked in the EU, but here we had the wringers for a long time before automatics came out. Even then, women typically washed for 10-15 minutes, enough time to rinse twice the previous load with wringing in between. Detergent manufacturers knowing this developed their products to work well in relatively short order. When the switch to automatics came about, detergents were already available for about a 10 minute wash. Since automatics saved the homemaker so much time and effort, short and efficient wash cycles mimicked how the wringer was used.
While the first automatics were frontloaders, Bendix gave a relatively long prewash at 6 mintes before the 9 minute main wash, thoroughly removing the dirt (we know rinsing was another matter). Westinghouse had a significantly longer wash times (IIRC about 20 minutes). The war set everything behind, but post-war was the toploading automatic boom.
Does anyone know why frontloaders were so much more popular in EU than tops? Were agitator wringers and twinnies the order of the day before the war, or was it semi-automatic H-axis washers that easily converted to automatics?
Many European and UK homes/kitchens simply aren't as large as those found in the United States. Front loading washing machines are easily fitted into small kitchens or some other area of a tiny apartment such as a bathroom or WC.
Yes, twin-tubs, and wringer were around in Europe, just look at some of the photos posted by members from the EU. Or, check out various European appliance maker's history museums, such as Miele's or V-Zug's.
Main differnce between European wringers and twin-tubs versus their American cousins, is the former most always had some sort of heating system (electric, wood or coal fire), to accomodate the boil washing European housewives and laundries wouldn't be without.
L.
The explanation I have been given about wash cycle times, water consumption and overall quality of the wash does come down to a few things..
Water consumption
Older front load machines used at least 50% more water than they do now. My old Australian built Hoover Electra was rated at 4kg and used 90ltrs or 22.5ltrs:kg....my 2 1/2 yr old Westinghouse (Zanussi-electrolux) is rated at 6.5kg and 72ltrs or 11.1ltrs:kg.....thats less than half the water and the Electa was considered efficient!
Detergents
Are more complex chemically than they used to be and with the lower water levels, lower phosphate content need longer to be effective on FULL loads...
Capacity and Load used
Machines now hold more - technically. Try weighing out the capacity of your machine and then getting it all in. Most of us only put enough in the drum for it to be 'comfortably full'. I was always told to put enough in so that it 'moves back and forth' as you try to put more in...then take 1 medium sized item out. It has never let me down. I can wash on the 40c Quick wash and get A1 results as my load is about 2/3rds rated capacity.
So try not putting quite as much in, use a good powder detergent and warm water and see how you go....and your machine should last longer too...spinning capacity weight every time does horrible things to bearings...
Oh, and my machines normal 40c = 117min...quick = 68...
Hi Jamie,
I have a W4888 Miele which I've used programmed in AU and Euro Modes.
In AU mode a Cottons 60degC takes 40mins on normal or approx 2:05 on Intensive.
In Euro Mode the same cycle takes about 1:10 on normal or 1:50 on Intensive.
This machine is hot and cold fill and and I've tried it as cold only as well as hot and cold and it performs pretty well either way. The issues I found with the AU Mode is that quite often it would complete it's last top up fill and then drain 2 or 3 minutes later. This left me wondering how wet things were getting for the majority of cycles. I've found that the extra 20 minutes makes a difference. I dont use a Euro Powder but Drive matic which is loaded to the eyeballs with Phosphates and other environmental nasties, but gosh it does a great job. Have you tried using a little oxygen bleach?
Before this one, I had a W2515 which was cold fill only, it still only took 40 minutes for a cottons 60 cycle, so the 2.4kw heater is going to be able to heat cold to hot in that time. My 1970's Miele takes 70 minutes for light soil or 2:10 for heavy soil. But it has a 3.2KW heater which it needs for the huge amounts of water it uses. (130L per cycle)
If you're using the extended option (Same as my Intensive) how long does that push the cycle out to?
Cheers,
Nathan
One other thing in relation to Ariel Powder, I spent a ludicrous amount of money on a large box about 3 years ago, and found that the rinsing was terrible. Even at 15 or 20mls per load and water plus turned on, it would still finish a cycle with thick creamy suds left behind. At that time we had a water hardness of about 3deg.
I gave it to Michaels mum and she finished the rest of the box off in her DD Whirlpool without issue.
Europe
Overhere in Europe wringers were also used for a very long time. The first automatic washer that was installed in a home in the Netherlands was a Bendix from the USA. In 1954 Constructa introduced the first European fully automatic frontloader on the market. V-Zug in Switzerland already had introduced an H-axis toploader in 1950, but that wasn't fully automatic, you had to manually adjust the programme settings. That was one of the few semi-automatics that we got here in Europe. No need of handling wet laundry though, it was all done in one drum including spinning.
Why Constructa and V-Zug chose for H-axis machines? I'm not sure about that. I don't think space was the reason, those early frontloaders were bolt down machines, not suitable for installing under a kitchen counter. Most of them had a soap dispenser on top so that made an under the counter installation impossible too. And these frontloaders were wider than modern European machines. Modern European frontloaders have a standard width of 60cm (23 something inches) while the older frontloaders were 68 cm or thereabout.
My wild guess is that because of the different way of heating water (most smaller houses and apartments had flow through water heaters, although in the UK that was different I think) it took longer to fill a washer than it did in the USA from a tank water heater. They designed a washer with a heating element. That wasn't a problem at all because 220V had become a standard by then and 380V was easy to get. Heating elements of 6000 Watts weren't unusual in early frontloaders. It made more sense though to heat a smaller amount of water in a frontloader than a full tub of water in a toploader.
Here's an ad for an early Constructa frontloader.
the Greek story
At Greece the first automatic washer was a Candy and it was called "Candy Robot".
Before that; many many people used twin-tub washers with agitator.
My grandmother told me that at the 60's a Toploader washer (she didnt remember brant) with agitator and spin cycle was being advertised. It didn't sold too much because it needed hot water!! At the 60's the only way to heat water was Electricity and fire! heating water all day was something expensive because the electricity was too expensive!! at the middle of 60's Izola (a Greek company) made the "Apollo" series of automatic washers with internal water heater and very very good price! Befoce Iozla the only automatics were Miele, Candy, Siemens , Indesit and they were expensive (5,6 salaries for a middle class citizen).
Now after 40 years american type washers comming to Greece ! the electricity is still expensive but Gaz came to our homes (and gaz heaters too). The 60% of consumers buys Hot field washers ; and with short times of wash! The new electrolux with variable wash time is top listed.
The most people want a cycle being completed in 50 min.
I bought a second hand Maytag Nepture and now I have a full load ready in 45 min!
P.S. Water at greece is VERY CHEAP! we pay 20€ per year!! (so we dont have any problem with High water level)
Now about the detergent; I use liquid only for darks.
Once I tried to wash whites at 95c (using my electrolux Timeline) with Ariel liquid and the result wasn't so good.
drum volume - capacity
I do agree with Rohnic about capacity. The load ratio for cottons is 1:10 - meaning each kg of load requires 10 cubic decimetres (also said "litres"). Commercial machines follow this standard, in household washers things are .. how to say ... "flexible"
Since Axxis and Dreamspace/Big (Duet euro versions) entered EU markets, other machines "grew up" their capacity (even other BSH and Whirlpool). The idea was to keep the standard dimensions 60x60x85 cm. For sure the 92 litre Duet drum can't fit in. So .....
... a 42 litre drum (4.5 kg) now is rated 5 kg or even 5.5
a 46/47 litre (5 kg) now is 6 kg
a 53/54 litre (5.5 kg) now is 6 kg or even 7 chez zannolux
a 60/63 litre (6 kg) now "can" hold 8 kg (zannies-aegs-whirlies)
This is quite evident : if you compare i.e. y2002 and y2007 Aeg or Zanussi brochures, now they are beyond Bobloading mode
Not to mention the Hoover Vortmax "9 kg" ....
Even Miele started kidding (perhaps only here in Italy till now ): i.e we've no more W3923 (6 kg) but W3943 (6.5 kg). I bet both machines have the same drum, otherwise these "bigger" 6.5kg mieles had come out earlier in Germany
http://www.mieleitalia.it/product_list.asp?L=1&idMen=163&cat=101011011
Capacity right big laugh over here. If I look at what I can fit in my olympia and my miele... it's still al lot and sometimes more then 5 kg (both machines are rated 5). Even a thick duvet fits in my miele, because of the smaller door it doesn't fit in my olympia. Note that the problem is not really the washingmachine, but the dryers! Once a 111 liter drum was only big enough to dry 4.5-5kg, now the same load has to get dry in a drum of 100 liter at max. The 111 liter is big enough to dry an 8 kg load? Still not impressed. Mostly because of the wrinkling, longer drying times and no space for sheets to move freely I think that it would be a lot nice for machine companies to use the ratio 1:10 for washer and thinks its 1:20 for dryer (or is that too large, thought it once 1.5 times the washer ratio?)
Hot water in Europe
There's a bit of a myth going around on this board that European houses don't generally have central hot water heating. This is simply not true, the vast majority of European houses do have hot water systems which are broadly similar to US systems.
The main reason why washing machines do not take a hot fill anymore is because the fill levels are so low. The machine isn't drawing hot water for long enough to clear the 'lag' of cold water in the plumbing. It makes hot fill pretty pointless. So, it was simply done away with. As machines became more and more water efficient, the hot valves vanished.
Also, because the vast majority of washing in Europe is done at 30 to 40C, it makes more sense to simply heat the water in the drum. The machines have always had heaters anyway and it provides a much more accurate level of control over the water temperature than trying to mix hot and cold water.
There's also a risk with hot fills that you can get water that's much hotter than 60C, particularly in older homes where hot water systems may not be as controlled. This risks damage to clothes and law suits for washing machine manufactures.
As a result of all that, they simply stopped including a hot fill valve in their machines, it's not a case that there is no source of hot water in most homes. Even in the old days, when most machines did have 2 fill valves, if there was no hot water source available you just used a Y fitting to split the cold feed and connected it to both the hot and cold valves on the machine so that it would always fill cold.
While it is true that some older houses in Europe may have instantaneous local water heaters under sinks etc, it's certainly not the norm. The majority of homes do have central heating and normal hot water supplies.
mrx - eurHot water
It is not a myth. You're true regarding nowadays. But not about the situation in the 50ies and the 60ies. Surf in the http://www.waschmaschinen-forum.de/ --->bildes der tag -->archiv . Here you can find some old ads that show those heaters over the kitchen sinks (one AEG for sure, over a drop down lavamat)
My granny in the 50ies had a "Elbow Grease" washboard, water had to be pumped from the well with the same EG tech (turning the pump wheel), water heater was a tank in the wood fire range.....
Hot water for Europe, and why we have front-loaders...
Mrx, I'm afraid you are a bit off the mark with your reasoning about cold-fill only. There are a variety of reasons why EU machines are (now) cold-fill, and one is the tradition that in many parts of Europe, central hot-water systems were comparatively rare until recently. The central-heating phenomenon was a feature of the 1970s and 1980s in Ireland and the UK alone. Prior to that, if houses had a 'central' hot-water system, it was generally based around a solid-fuel range cooker, or back-boiler (an open fire that has a water boiler attached) - just think of the endless quantities of Victorian and Edwardian houses in Ireland and the UK that weren't equipped with heating until very late in the 20th century. If the house was on the 'town-gas', hot water might come from a geyser over the kitchen sink. Also remember that rural-electrification was still just reaching parts of Ireland as late as the 1960s, in spite of having dated from the Siemens-Schuckert work at Ardnacrusha in the 1920s and 30s. Others might like to comment on other parts of Europe, but I'd wager that you'll find similar evolution there too. Mainland EU washers are often located in laundry rooms with cold-supply only (like the commonly found wash-kitchen in Germany aprtments), so dual-fill washers were impractical.
Cost of living and wages have had a major impact on this too - in the 1960s a industrial 'professional' starting salary was in the region of £1000 per annum. Nowadays an equivalent role would attract 40 times that amount. If we whizz back say 45 years, you'll find an automatic washer (like an English Electric or Hotpoint) cost about £105 in the UK - that's 10% of an annual professional salary!!! In modern terms, that would mean the equivalent washer should cost £4000 (that'd be a commercial model then...). So it is fair to say that automatics were out of reach of most people in the 1960s, and as such the twin-tub at reigned supreme from the 60s through to the late 70s. Hyper inflation the 70s also has an impact, but as production increased, costs could be saved and gradually machines got cheaper (add in mechanised production and you save a lot) - and the quality dropped. If you compare the engineering complexity of a 1960s Hoover Keymatic, English Electric Liberator or Hotpoint 1500 to a modern machine you'll see that every aspect has been engineered down to minimize cost. The separate chassis gave way to cheaper monocoque design, plastic replaced metal, concrete replaced cast iron and clutch drives gave way to simply bad balance control.
Towards the end of twintub production, the machines were 'unrealistically' priced for the market - almost £400 for a Hotpoint - way more than a cheap automatic, and a reflection that volume fall-off and build costs were the down-fall. Ditto the Hotpoint TL - just too expensive to build and still make a profit and not enough people to buy them. The market expects to pay very little, so manufacturers have to make machines as cheaply as possible to remain competitive and produce washers that cost as little as £150. You'd be amazed at what lengths manufacturers will go to keep costs low, and profit margins high - so if dropping a water valve and a hose pipe saves say £1 per machine and you make a million a year, you're saving a lot! As the former UK marques are now owned by EU (Italian to be precise) firms, 'manufacturing rationalisation and harmonisation' would mean it only sensible to eliminate regional features that are not required in the general market - so the UK/Ireland hot valve has gone! In order to smooth the change, we're sold this is a great advance, saving us lots of wasted hot water and money, and promising better detergent performance - this is marketing propaganda to cover up a very obvious cost-cutting/rationalisation exercise. As someone else noted, the German manufacturers are now offering hot-fill as an eco-option (who'd have credited it) - I bet we'll be asked to pay more for this!!!
As to why we have front-loaders - hard to say...in Ireland and UK in the 60s we had every possible type of automatic - agitator (Hotpoint, Servis and Frigidaire), top-loading h-axis (Phillips etc), and front loading, as well as the unique hybrid Hoover Keymatic. I guess the fact that the US Bendix machine as one of the first to be manufactured in mainland Europe had an big influence on design. Washers are generally fitted in kitchens or bathrooms in Europe, with only very much larger houses have laundry rooms, so with the advent of the fitted kitchen (again in the late 70s), under-counter washers won the day...
