Exploring the Fisher&Paykel TOP LOADING dryer that came thru...
redcarpetdrew
Apr 12, 2008
3,751
Fairfield, CA
I don't see much in the way of Fisher&Paykel laundry around these parts but had seen a top loading dryer in a customer's home and wished to see how the drum door worked. Well, thru The Pile came this one. F&P DEIX2 Intuitive Series top loading dryer. Play... eerrrmmm... Explore time!
The 'lifestyles' button has a few pages of special, preset cycles for your laundering pleasure. For example, the allergy setting is an extended tumble, high heat cycle to kill off things in the clothing. like a 'sanitize' cycle, perhaps...
And still more... I'm listening to it run behind me as I post this. Am I imagining things or does this dryer occasionally stop tumbling and reverse direction for a few seconds then back to normal direction? It seems to be doing this in a regular pattern. As I said before, I don't have a lot of experience with these. Anybody own/use these? I see they sell them in Australia, the U.S. and Canada. If you have one, how do you like it?
The dryer moneyshot...
This thing looks gigantic inside. I'll hazard a guess that large comforters and blankets fit nicely inside although I'll bet it's a bit of a pill to reach down to the bottom if you are short or have back issues...
To answer your question, here's the inside... In back, this is powered by a setup that looks like an overgrown microhood blower motor. Double shafted, one side has a big blower wheel for air movement while the other powers the drive belt you can see on the right side of the drum. The element and one of the control boards is up front. This thing has THREE control boards. One for the user interface, another up to along the left side of the dryer and the one below. Sounds different, too. I find the method it uses to open and close the drum door really interesting. I shot some video for those who wish to see it in action.
OK, F&P fans, what do you think of your machines?
RCD
<object width="425" height="344"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I have one of these dryers and my mother LOVES it! The drum does look big however, I'm pretty sure it's only 6.5 cubic feet. The lint trap has a scraper that sweeps around when the lint reaches something like and 1/8 of an inch thick and dumps the lint into the bucket which needs to be emptied once full. (It takes several loads for the bucket to fill up.) The downside to the lint trap is that every time it scrapes the lint trap, which is rather frequently since it allows so little lint to build up before scraping, a lot of lint gets pushed through the screen and ends up in the vent lines and all over the lawn outside much more so than the Whirlpool dryer that sits next to it! I will say that I too love this dryer as it does a fantastic job not to mention it sounds REALLY COOL!!! lol
horizontal axis toploader washer
Lebron, you're right. There are just 3 manufacturers in the whole world that make TL dryers. The others are Candy Group and Fagor-Brandt Group.
Maybe someone will enjoy also this vid . It is a horizontal axis toploader washer [Jamie .... it's a Miele ! :) ]
I have this F&P dryer and matching washer.
It's the best dryer I've ever had. And, yes, it does reverse tumble. This keeps things, especially sheets, from getting wadded up.
The dryer is fast (mine is gas) and when it says they're dry, they're dry. None of having to re-run some of the items because they're still damp.
Loading and unloading is easy. You simply bend a little instead of stooping down or bending a lot.
The matching washer is great, too. It spins at 1,000 rpm. Cleans well.
I've had this set for about 4 years now with no problems at all.
Thanks for the video. It's interesting to finally see how things move under the cover.
Jerry Gay
Thanks for the video Andy. I've used this dryer at Glenn'numerous times. Ramping up it sounds so space-like or robot-like. It's a very thorough and gentle dryer. The wrinkle guard can run for up to 24 hours I do believe. Glenn has commented to me that if he leaves jeans in the dryer and let it goes through a whole 24 hour "cycle" of wrinkle guard, the jeans come out extremely soft.
