Try this-
Large skillet with cover. Electric or stove-top. (I use a 12 inch Farberware Classic, either electric or stove-top). Heatproof "rubber" spatula is helpful.
In about two tablespoons of real butter (or olive oil, if you must--but not a nearly flavourless oil like canola-)
Saute until tender and lightly golden: one finely chopped onion (about tennis ball size). Set aside in bowl or back on cutting board.
Slice 12 ounces or so of mushrooms. (thin slicer on processor, if you have a thin slicer, if not, use the slicer disc you have). If you don't have a processor, use the little manual wire hard-cooked egg slicer. I like a mix of regular button mushrooms and criminis ("baby bella's) Add a little (just a little) more butter or olive oil, and saute mushrooms until they give up their water, and are delightfully fragrant. Stir frequently. Does not have to be constant, but definitely frequent stirring.
Peel and finely chop 1-3 cloves garlic, add.
Chop one bell pepper (capsicum), red or green, or half of each. Put in half of the chopped pepper, keep stirring.
Add the onions back in, stir.
Add one measured cup of dry rice (I use Uncle Ben's for this). Stir for a minute or so.
Add 2 cups and about (eyeball it, no need to measure) a tablespoon of chicken broth, preferably low salt (I like the Swanson Natural, in the aseptic brick pack). If using regular broth, be careful about adding salt.
Grind in a LITTLE black pepper.
Bring to boil, stirring every so often.
Lower the heat, cover.
Cook on low for about 20 minutes. Uncover and check at 15 minutes.
Just before serving, add in the rest of the chopped pepper, stir in. Taste for salt and pepper, add more if desired.
I like to grate some Pecorino Romano, or Parmesan on top of my portion. Pass the cheese and the grater.
Makes 6-8 servings.
Reheats nicely in microwave.
Lawrence/Maytagbear[this post was last edited: 11/12/2011-16:11]
