Fabric damage in a filtrator is really not much of an issue if you know what you are doing and use some common sense.
In normal operation things should never get hot enough to cause either degradation, melting or scorching of fabrics. Fabrics such as polyester will start to signs of degradation at around 350 degrees but do not actually melt until about 500 degrees. Nylon and Dacron are similar. Dry cotton will begin to scorch at about 400 degrees. The normal operating temperature on High for an early filtrator is 210 degrees at the thermostat bulb on high. In practice this means that the temperature in the middle of a dry load can approach 240-250 degrees. That's pretty hot, but not hot enough to cause damage first of all because, if timed correctly, things should never actually get so dry that they get that hot at the center. Secondly, because there is so much steam present in the drum for most of the cycle it is hard to over dry things, again, as long as you keep the cycle times sensible. Also, I don't know anyone who actually sets these early dryer on the HIGH setting. I use the medium setting for cottons and LOW for blends and synthetics.
