Finally found a dishwasher! Kenmore rotorack!
snail
Jul 1, 2022
59
Granite Falls, Washington
I picked this baby up in missoula MT on a road trip heading west back to Seattle. I actually spotted it a month ago and the seller agreed to hold it for me until my trip! It appears to be in fantastic condition and missing no parts. I think it will work very nicely in my mid-century kitchen. I'm guessing early to mid 60's on this model? I've yet to try it out. I plan on popping the back cover off and giving it a once over first. Maybe take the timer apart and relubricate it. I have not seen another one exactly like this. Is there anything specifically I should watch out for on one of these?
It's more like a mid to late 60s model, which is good because you have a lower wash arm instead of an impeller!
If you could post a clear picture of the model tag, it should have a date code in the model or serial number to pin down the exact year.
I've got an older Kenmore 600 portable Roto-Rack - before using, I'd suggest checking the hoses and you may want to replace the hose washer where the fill hose connects to the water solenoid valve.  Before trying to start it up, pour a couple of buckets of very hot tap water into the tub and let it soak for about an hour.  This will help swell gaskets that have likely dried up in storage.
I think part of the short upper spray arm, meant to direct water onto the upper rotating rack as it turns, has fallen off.  Hopefully it's not broken and you can just slip it back on.
The detergent dispensers on these can be a bit wonky.... mine's in deep storage at the moment but I had a lot of trouble getting them to trip at the right point of the wash cycle.
Definitely a great save!!
I'm finalizing the plumbing at my new place (I'm putting in a whole kitchen).
Can I connect this dishwasher to a permanent water source or would it require a shutoff valve?
I don't know if you have used a roto rack before, but on the off chance that you have not, I will give you a hint from when I had one and accumulated a full load over a couple of days. Only load one side of the top rack until you do the final loading of the bottom rack because you have to flop one half of the top rack over onto the other half of the top rack to access the lower rack. You can distribute the top rack load after that and it needs to be balanced to spin properly.
IIRC, these have no food particle filter AKA soil separator. I've found just as with many D&M manufactured dishwashers I've owned, that it may be necessary to be very thorough removing the particles before loading. Glasses do come out of very clean out of roto-rack models.
Connecting a portable dishwasher to water permanently
This can certainly be done and makes the machine a lot more convenient to use.
You could install a wall box like you use for a washing machine with a hot water tap and a drain to put the drain hose in you always have to have a shut off valve where the hose connects to the house is plumbing, you can use a washing machine inlet hose that was screws directly on the inlet valve of the dishwasher.
And of course, the other good thing of hooking it up with hoses as you can unhook it to make repairs easier and you may also find this machine is not likely to last very many years so you can just change it out for another portable dishwasher that you might find that you like.
John
Wall box...
<span style="font-family: helvetica;">I have a portable dishwasher hooked up into a wall box as John has suggested and it works really well.  In my case it shares the box with a washing machine.  I put a Y valve on the hot water tap which allows me to easily control when the water is on..  Because I don't use it daily I turn the water on when I am going to run it or if I will be using is a few days in a row I may just leave the water on.  </span>
<span style="font-family: helvetica;">It's about 40 years old so I figure no need to leave the water turned on to it if I am not running it on a regular basis.  In your case you can just leave it on all the time but if you need to shut off the water, it's pretty easy to do.</span>
<span style="font-family: helvetica;">It's installed on the wall just below the top of the dishwasher so you dont see it.  It's an easy change to switch dishwashers if you want.</span>
Wall box
Yes. I thought about the wall box possibility. I considered making it out of tiles with a built in drain and a spigot so I could connect it with it's coupler. Then I can still wheel it to the sink for easier loading. It would just be so much simpler to connect it the same way a typical dishwasher is hooked up. The utility sink will be on the opposite side of the wall so I thought I could tie into the sink drain there. I considered using an electronic solenoid valve in the wall to shut the water off after every use if required. Idk. I will have to make some kind of decision this weekend..
