lordkenmore
Well, Panthera, even with all those systems, there might be issues of something leaking out when the door is opened to toss in wood... Of course, how much of a problem wood burning with any given system raises depends heavily on how its used, and the people in the environment.
The other minus I see with all those systems is that they sound like they need power to work...and so if the electricity goes bye-bye, I assume the wood burner won't work. It seems to me I've heard this as a minus for some systems like wood pellet stoves--it requires power to run.
Outside air supply for combustion is not news to me. No idea when it came to be, but I remember having conversations with the guy who used to maintain the place where I live. He was fired up (ha!) to install a wood stove here--which I'd have liked--but the problem is I live in a mobile home [Gag. Shudder.] But a problem we hit: it would have to be a cheap installation, and one of the big stumbling blocks to that was that wood stove had to be a special one with combustion air intake from the outside, which poses problems when used stove shopping. But stoves like that apparently just have an unforced air connection (a pipe leading outside, no blower) or so I gathered. Meanwhile, you could get any stove used--even one sitting in a ditch, rusting away--and toss it into a real house, and (as far as combustion air supply was concerned) no one would care, or so I gathered. The fire department, however, might not approve of a rusted-out stove on other grounds...
