mark_wpduet
Most of the time I've just been really lucky I think to have never needed a plumber or was able to fix something myself. Example... Two or 3 times I've replaced the toilet fill valve/ seals... once my kitchen sink got terrible clogged but I was able to get that myself...and another time we replaced an electric water heater ourselves... but plumbing freaks me out...
My house is on a concrete slab..2 bath.. One of the toilets has leaked perodically from underneath... then it will stop for a long time... then it will start leaking again and it's freaking gross. The other thing is the kitchen faucet squeals when I use it...like a screeching sound.. I can only describe it as sounding similar to a tea kettle (but not exactly that sound).. that's the closest thing I can think of..
So the plumber gets here...and guess what? It's NOT the wax ring... the toilet was uneven so he had to shim it... He said the wax ring looked fine and that wasn't the problem. He fixed it and replaced the wax ring.. He said the unevenness would explain the leaking only periodically... but it didn't feel like it had an unevenness to it...I guess it was slight enough that it wasn't noticeable.
Now... the kitchen faucet... He spent 45 min's trying to get that thing off... the bolt had stripped so he had to cut it off... I'm thinking holy crap I'm so glad I didn't try to do this crap myself...
My sink is from 2004.. it had a standard faucet and a separate sprayer inside the base. I wasn't sure which one to buy. He said those are now special order and they are very difficult to find...but found a supply place that had one. I needed the same type because I connect a water filter to it.. I would love to have one of those pull down sprayers but then I couldn't connect my reverse osmosis countertop unit to it... which I've used for over a year now and fell in love with it.
He was here about 3 hours. Total? $700
Probably a rip off but I do NOT care... I'm so glad to finally have a sink that doesn't squeal when using it and a toilet that doesn't leak anymore.
He was really nice. He said...is this a new toilet? he said even the bolts look new... I was like.. .No it's 20 years old.
Lastly... GET THIS: when he first arrived he said "You have a problem". It looks like your water heater is leaking...I said HUH??? he said yea I see the water leaking from the pipe coming out of the house outside... It was the AC condensate drain.
I know all plumbers are outrageous and I could have called some small handyman to do it...but I don't know any... so I just went with a reputable company knowing it was going to be outrageous and hope this is this LAST time I ever have to call a plumber
anyway.. here's the new faucet
