First Westinghouse Laundromat
Jeff
that is STUNNING !
Rich might have a point this could be a prototype. Westinghouse paid Bendix the sum of $125,000 in 1938 to get use of the rinse/drain feature Bendix had patented. So in 1938 they were still developing the machine. If this is a 1940 that is only two years later to be building a full commercial model and then the war broke out.
Super Interesting!
It's not every day you see something this history-packed.
I'm very taken with the detail on the load door handle - that looks like a chrome-plated die casting with paint fill in the lettering. Grey or light grey-blue for the "Westinghouse" and dark red for the "Laundromat."
Today's bean-counters would have a hemorrhage over that.
I am glad someone got one of these
Here is a picture of one that was for sale in Glendale, CA years ago on craigslist. I tried real hard to get this but never got a response from the seller.
Testing so far-
Motor won't run and smokes, taken out for repair and testing. The transmission was stuck in spin mode. I took the rear cover off the trans. and found almost no trace of oil inside. With a little oil got the shifter freed up. Will make a new cover gasket and replace the rear shaft seal, then refill with proper oil. Overall the insides of the trans. look good, no sign of moisture or worn parts.
Jeff Thank You! for an interesting thread.   Both examples pictured in this thread show very little rust.  The inner door had  to be superior and more expensive to manufacture that the later machines with  the rubber boot?
So awesome!
I know if John and Jeff have not seen this model it is very rare!
It looks cosmetically to be in great shape.
VERY COOL!!!
i'm not too hip to westinghouse washers, but this one is definitely a GREAT find loaded with american history. reading about this front loader is very interesting. i'll keep checking this thread to see your progress and hopefully soon, we'll get to see some washing videos!!!
GOOD LUCK with the restoration. i hope it's not too difficult for you!!!
keeping my fingers crossed for you........
;o)
Ours (my first) was barely postwar, most closely resembling the 1948 'show' pic. No pump filter, no pump belt, wheel-to-wheel drive solenoid engaged, entire lower skirt came off. Suspension was L&R + rear coil, top/side/bottom leaf snubber. Water metering was off the bottom leaf-- weight. Single dial set wash duration and temp H/W/C. Rinse was W. Spray rinse during both wash and rinse spins. Yeh, 500RPM sounds right, definitely not 1500.
This is fascinating...
Having worked in engineering for 30 years these discoveries
really grab my interest. It's amazing to me the things that we were
doing in those early years of the technology boom.
Jeff, one question I have is, is this a hard mount/bolt down machine
or a suspension machine? It's a little hard to tell from the pictures
so far.
Bill
