I ran another load of jeans last night, 5 pairs. Three pairs on the bottom, basically folded in half and arranged evenly around the basket. The remaining two pairs on top, not folded, each 'wrapped' half-way around the agitator. I did not reset the water level sensitivity to the default mid-position. It settled on medium-high water level ... so either it "learned" from the previous load of jeans or the loading pattern was different-enough to generate more 'drag' on the fins during sensing.
Burpalator, the two washer models GWL11 and IWL12 are mechanically identical. The difference comes entirely from changes to the control panel and programming on the controller board. I don't think the more expensive model is inherently less reliable. There are no moving parts on an electronic controller board, and *both* machines are completely electronically controlled. IWL12 has much more flexible cycle selections and options, and automatic fabric sensing whereby it determines the average fabric mix of the load and automatically sets the agitation speed from a wide range of choices. For a typical load one simply presses Power, adjusts the Soil Level if desired, and then Start. No need to select Regular or Delicate cycle, the machine figures that out. Selecting a lower (or higher) soil level will result in both a shorter (or longer) wash period and a gentler (or more intense) agitation action for a given load.
IWL12 also offers
- a menu of pre-programmed LifeCycles to deal with specific laundry situations (stains, shoes, comforters and other bulky items, beachwear/sand, sweaty clothes, etc.) that provide temperature combinations and combinations of wash actions (prewash, soaking, multiple rinses) that aren't possible on GWL11
- differences in the default rinse selection and a couple more rinse options
- fine-tuning of water temperature, and (possibly) higher allowed temperatures
- an LCD panel with a cute smiley-face, text messages and cycle progress icons
- direct access to a full-fill hot wash, which GWL11 "hides"
- a very gentle Handwash option (which may be gentler than Delicate on the GWL11, I'm not sure)
- more choices for delay-start times (no big deal)
The frontload dryer is built in Canada by Camco, which is basically GE-Canada. The topload dryer is native-F&P. I have an older DE04 frontload dryer (1999) that my grandmother is currently using, never any trouble with it and performance is very good ... although I can't necessarily say the same about the current '08.
