Flashing lights on Speed Queen FL after cycles completed?
revvinkevin
Jan 7, 2007
5,592
La-La Land
A friend recently purchased a stacked Speed Queen front load washer & dryer. While it needed some cleaning, it works well, or seems to anyway. After running a cycle, once it’s complete, the “door“ light and the ”wash” light flash slowly and the washer will not start again until it’s been unplugged, then plug back in.
One other thing, it doesn’t seem to drain very fast, but it does drain completely. One thing I noticed last night as it’s draining before spin, the tub rpm starts increasing while it’s still draining. I could hear there was still some water in the tub, but it was gone 2-3 seconds later.
Any thoughts?
Thanks in advance![this post was last edited: 8/17/2019-13:59]
Balance and Drain
The distribution balancing while the machine is draining is normal operation.
Wash Light and Lock light might be an issue with the door interlock.
Malcolm
