Fle3000 issue
fle3000
Feb 15, 2021
4
Herne bay kent
Hi guys am new to this group I got my self a zanussi fle3000 about 18 months ago to has developed an issue where it keeps giving me an 1a error code towards the end of a cycle if u turn it off and back on it will continue then the code comes back do the same again and it will finish. Would this issue be the motor or brushes have read up its saying not heating but it is please help shes a lovely machine
They don't like the cold
Hi , it could be due to the temperature of the incoming cold water . Has this error only started with the colder weather. I remember long ago when i used to work on this model range reading a technical bulletin , it stated that if the incoming cold water temperature was very low the ntc temperature sensor would read this as an error. It could tie in with when the machine is loading in more and more cold water for the rinsing. I guess they were designed with Italian water temperatures in mind. Just a thought. Nigel.
fle3000 1a error
hello sorry for the long delay i am still having issues with the fle3000 giving me the 1a error code its now starting to do it whiles its filling up i really dont under stand it can any one help
1a error
thanks for the reply the strange thing is the heater works ok during the program am hoping it is the relay thats on the rear of the machine but i dont know if you can get them as spares as all. i had issues with the machine a few weeks after getting it the drum was leaking but thats sorted i managed to get an other zanussi with the same drum and do a swap
hi it was a fl1024 we didnt swap the heaters as the donor one was new and of same type am thinking the hearter relay needs cleaning after all these yeahs with contact cleaner the motor for the fle3000 is a brand new one
Heaters
Ah - be very cautious of assuming that just any old heater will do...
In the days of the Hoover 'New Wave' (electronic machine) and Hoover 'Classica' (electro-mechanical timer), the service manual stressed that the correct wattage heaters had to be sourced for a particular machine. Failure to do so could lead to wrong temperatures, or possibly programmes being aborted in the electronic machines.
Also, check the wiring between the thermistor and the PCB, look out for corrosion at connectors, or broken wires.
