seeitrun2006
I have a Whirlpool dishwasher model #DU1055XTSB1 purchased February 2007. During the main wash it has started to develope foam. When this happens it does not wash well and end up with partially dirty dishes. I've been putting a little white vinegar in it to clear out the foam. The wash action improves and finishes the cycle.
A couple of months ago I checked and cleaned out the pump. I found three tooth picks in it.
We are using Finish gel pacs in the main wash compartment of the soap dispenser. The rinse aid dispenser has liquid in it. I'm wondering if the packs are not dissolving and plugging up the drain. We use the "High Temp Wash" on the Normal cycle. If it does not improve soon I am going to open the pump assembly up again.
Before we used Fisnish liquid in both dispenser departments with no foaming at all.
Any advice would be greatly appreciated!
Thanks!
David
Thanks!
David
