Foghorns,Diaphones,Diesel motors-like them all!I have a DVD recording of the Auditorium Organ that shows its 64' Diaphone in operation as shown.From listening on the DVD and on the link it sounds like a large low speed diesel engine-live,to the ear sure it sounds different.And I am sure the LF fundamental frequency is enough to shake you!And when you listen to the Diaphone recorded-only very few speakers could reproduce its fundamental tone.And to reproduce that sound will require LOTS of amplifier power!LF speakers are not efficient.
Diesel Motor-we have a 2.2MW Caterpillar 4160V 3Ph genset at the site.It has a Cat 3816 series engine-16 cylinder 3000 Hp max.Ours has two 24V starter motors and it can be started remotely from our station control room,or automatically in case of power failure.The Cat 3816 is said to be used in some locos-according to the Cat techs that service our engine.
Forghorn-There was a man that used to work here-he retired,he was a member of the Coast Guard.One of his duties was maintaining lighthouses and their foghorns.The ones he dealt with were electronic.No compressors or diaphone horns.He said he worked on the last generation of foghorns.The electronic ones replaced many of the air powered ones-were cheaper to use and maintain.Their equipment took up less space.The air ones-well are just more spectacular.The side cylinder recip compressor used in the SF one was like an Ingersol Rand Compressor the DC plant building used before it was replaced by a Quincy rotary screw compressor-these supplied the building air.Each was 60Hp.Remember that old IR compressor going "thump-Thump-thmp" thru the headphones in some of the studios when the mics were opened and console gain turned up!The Quincy just makes a Hum and you have to be by it to hear it.The transmitter plant has two 10 Hp compressors for shop-building air,two 1Hp for HVAC system air,and 2 5Hp for switchbay air.Gardner Denver for the first two-Ingersoll Rand for switchbay.I just have to make sure these are running OK.Part of supervisor building checks.
