mrb627
Heat oven to 425.
In a wide mixing bowl, add 2 cups of self rising flour.
Make a well in the middle of the bowl.
Add 1 cup of cold whipping cream.
Gently fold flour into cream with a rubber spatula from the edge of the bowl to the center. Turning the bowl a 1/8th turn between folds. When flour is combined with cream (don't overmix) turn dough out on a lightly floured surface. Pat dough to about a 1/2 inch thickness. Lift edge of dough and fold in half. Dust away extra flour from the surface of the dough. Re-pat the dough back to 1/2 inch thickness. Fold in half again. Remove excess flour again. This time, pat the dough to about 1 inch thick. Using a drinking glass that is about 2 to 2 1/2 in diameter, dip glass in flour and then press out a biscuit. Do not twist glass or the biscuits wont rise properly. Transfer biscuits to an un-greased cookie sheet. Place them close together but not touching.
Bake in the oven near the top. Melt a 1/2 stick of butter in the microwave and let it cool till the biscuits are finished. At 6 minutes, turn the cookie sheet 180 and continue baking an additional 6 minutes. At the end of the 12 minute cycle, remove biscuits from the oven. Spoon melted butter over the top of the biscuits. Leave on cookie sheet for 60 seconds, then remove biscuits from the cookie sheet to a plate.
Enjoy.
(Someone else try this recipe and report back your results, I was amazed how fluffy they were)
Malcolm
Enjoy.
Malcolm
