For Lawrence(Maytagbear) How to replace your Convertible handle release pedal
hoover1060
Apr 9, 2005
3,309
OK Lawrence here you go. This is a pretty easy fix and will take you no time at all.
You'll need a flat blade screwdriver, and I recommend you set the cleaner on the floor someplace where you will be able to lean the handle up against the wall while you work.
I mailed you everything you need on Friday, so you should see that package sometime Monday, Tuesday at the latest.
First you'll need to remove the motor hood. There are two screws. The left one is located here:
right side one here
Loosen the screws. Depending on the vintage of your model 70 they may come completely out, on earlier models they stay in their respective holes
Once the screws are loosened, turn the cleaner upright and lift off the motor hood.
Remove the spring first
Grab it, press down, and pull it out from the top. Its not a strong spring...
once the screw is removed..
Lift out the pedal. Here are the parts you will have.
1 screw
1 metal pin
1 metal bracket
1 spring
1 release pedal
insert the pin in the new release pedal
as shown, and then put the pedal back into the cleaner base.
Be sure the handle bail pin is in the pedal slide!
next the little bracket
At this point you can raise the handle upright, and then lock it up with the new pedal if you are having trouble getting the bracket in where its supposed to be
screw it down tight
note also the pin from the handle bail and its position inside the slide on the pedal
finished
this is what it will look like all re-assembled.
If you have any problems, shoot me an email and I will help you
Jeff that was very interesting. You did a great job explaining it and the pictures really made it clear. Thanks for sharing you knowledge. Terry
Thank you, Jeff!
Thank you for the good pictures, and very clear words. Also, thank you for using a Model 70. I found that to be very reassuring. Mine is not nearly as pristine looking.
I am going to take this thread to the library and print it out. (Don't have a printer here.)
I think I could do that, even though I am pretty clueless.
Lawrence/Maytagbear
Have no fear Lawrence...
The swap should maybe take you 30 minutes start to finish, probably much less than that.
I don't believe for a second you're clueless.
I used my model 70 for accuracy, although that's one part of the Convertible that did not change much at all over the years. That pedal and its operation are pretty much the same and interchangable from the very first model 65's to the last of the Decade 800's, and even today's commercial Guardsmans.
You should have no problems.
Let us know how it all turns out!
