For only $15 at the thrift store
kimball455
Jan 21, 2011
396
Cape May, NJ
Saw this electric fry pan at the thrift store for only $15. I have a few in my collection and as this is oil filled thought it would be unique to have. As I said the price was $15. When I searched the web I was rather shocked by the price $349 for a new one. Think I got a deal and it works perfectly. Used it last weekend to poach quenelles and they were perfect.
Harry
Oil is an ideal thermal transfer fluid. At work all of our high pressure/vacuum reaction vessels are heated by an oil jacket. The boiling point of oil under pressure is very high and it had a very high thermal capacity so it is ideal as a thermal transfer fluid. Also, it will heat evenly and you will have less recovery time from the thermal shock of putting cold food in the pan so it should brown quicker too.
I have a set of Oil Filled Cooking Ware made by Lifetime.
They are wonderful for cooking once you get the hang of using them. Very well built.
Great find you have there Harry!
Brent
I have the Webalco version. They were made by West Bend and sold under various names like Salad Master etc. If you hold it up and tilt it you can sort of hear the oil sloshing around inside. Very even, but take a little while longer to heat up. You got a great deal.
Using the oil filled fry pan
The only thing I noticed was it took a slightly longer to heat up. Other than that I did not see any difference. Really steady temperature and great heat distribution.
Harry
Hi Tom,
To mirror what Petek said...
They take a little while longer to heat up, however the heat is very even and consistent. A nice feature - it keeps it's temp without any heat source for quite awhile.
What a great deal!
Stainless steel pot are prone to uneven heating. That is why you see higher quality pots having other material bonded or plyed to the bottom. Aluminum unfortuantely can melt if left on high heat, empty, for too long, especially if placed on a high BTU burner, like that of commercial or semi-commercial cook tops. Copper works well too but needs to be 1/16 thick to utilize its heat distributing properties as well. Having an oil filled core was thought to be a less expensive way of obtaining even heating. A stainless steel electric skillet is a very nice find in deed. One has to appreciate the ease in cleaning of stainless over aluminum as well as the durability too. The skillet, if kept clean on all surfaces, will stay new looking for decades!
nice find
I, too, am not familiar with Americraft Kitchencraft electric skillet. I'm always impressed with people find here. Saladmaster and Webalco, and Lifetime - when were these skillets made?
These type of electric pans and their matching cookware sets were often sold by independent distributors at expo's, spring and summer home shows, state fairs. The distributor might have a storefront in one of the larger cities of a region sort of thing and may also have sold some other equally non-common thing like Rexair Rainbow vacs or Compact Vacs, or "air purifiers" type stuff. Which might also be shown at those same venues.
