For You Whirlpool Combo Guys
This is for the earlier model line like I had with the flat lint filter above the pump, except that mine was bol and electric and this is tol and gas.  It used the same pump as the Bendix Economat which sucked air as well as water so that the pump could bleed air out of the system to lift water through the filter.
Tom, didn't this machine use the augur style pump? I was unaware it was used in any other machine. From my reading it worked best when the water filled the outer chamber forcing the walls of the pump housing closer to the augur and increasing it's efficiency. How did it suck air?
Alan, I'm very sorry you didn't win the literature bid.
Should have just kept well buttoned
Or perhaps made things known by whisper listing. It was only two persons bidding on this item so whoever winner was obviously wanted the thing desperately. Maybe he came upon the thing on his own, maybe from here; who can say.
As for losing an auction by $1, that is a common misconception.
In truth unless one knows what winner's highest bid was, one did not lose by only $1.00. That is if current highest bidder put in $100 as his best number, eBay system would only show current high or winning bid over previous amount.
If current high highest bid (including max) is $39, but someone bids $100, new highest bid will only be one dollar or so more than previous. But if previous highest bidder entered a max of $100, or $200, then the snipe/last minute or any other subsequent bid will be rejected and new highest bid would increase by one dollar or whatever, but still previous bidder is winning.
This would go on until another bidder exhausts previous max highest bid. In other words the "one dollar" highest winning bid you see could be at low end of maximum range. No one knows besides eBay and bidders that max number.
You can often see in bidding histories frantic attempts to outbid someone. Sometimes they are successful, others not. Those that wait until last minute to snipe often find they are out of luck if max highest bid keeps generating automatic bids (until max high number is exhausted), and or others are pouncing on same target.
In theory the old adage applies; bid maximum amount willing to pay upfront, then let chips fall where they may. Problem with that is you get idiots who have no intention of winning, but just keep driving up the bid price. This or those who keep testing the waters to see just how high things will go.
If one *really* wants something will go in with a snipe at last minute of several hundred (don't look at me like that), which normally does the trick. Of course one has to be ready to pony up if winning bid reaches an obscene number.
Launderess is spot on. When I have wanted something desperately, I sit by the computer near the end and make sure to watch the bidding. I have had to up my bid and Launderess is right, go for broke if you want it.
No Worries
Thanks for the kind sentiments. I'm not bitter or upset at all; just a bit disappointed that we all won't be able to enjoy the manual, and the great info it contained regarding a pretty rare item.
Now if was the actual machine, and it was near enough to me that it made economical sense to get it, than I would have been much more aggressive!! :)
