revvinkevin
A friend picked these up for me a week ago and I brought them home yesterday, the best part is they only cost the gas to go pick them up, as they were free!
I know they are older, but how old are they?
After fiddling around with the controls on the washer for a while, I was able to eventually figure out what the various controls do and get it to work. One neat thing I discovered is it has a rapid advance timer! Turn the timer knob (on the left) to one of the cycle program numbers and the timer starts clicking away until it catches up and the cycle starts. Another interesting thing is you must also select a wash temp (the right knob) because if it’s at the 12 o’clock position, the washer won’t do anything, it’s like a 2nd “off” switch.
Photos 7 & 8 are the wash and rinse water levels, respectively.
Today I ran a load of “play laundry” consisting of 3 pairs of jeans, 1 shorts and an old long sleeve work shirt. This washer must only have a 5kg capacity because it was pretty full. I’ll tell you this thing moves around so much during the wash tumble, I would swear it desperately needs shocks. HOWEVER this thing also wastes NO time ramping up to full spin speed and it doesn’t really care the shocks are loosey goosey!
It’s cold fill only and yet, can do a 200°F (95c) wash! It does 4 rinses but does NOT spin after the wash or every rinse, it only spins after the 2nd rinse, then the final rinse. Spin RPM is 900 or 1400. All in all everyhing still workes as its supposed to, except the (one and only) inlet valve doesn’t close completely and continues to drip if I don’t shut the water off. Overall I like it so far, it’s a neat little washer. The dryer works too, but is a bit noisy, sounds like the rollers have flat spots.
Kevin
Kevin
