USING 50 CYCLE APPLIANCES HERE
Both of your machines should work fine here if you properly change the plugs as described in the last post. The washer will spin and tumble 15% faster and the cycle time will be 15% faster YAY. The DW pump will produce a little more pressure as it is running 15% faster and as stated the overall cycle time will be up to 15% shorter. Probably again a big improvement.
You either have 240 volts or 208 volts at your home there is no 220 power in the US anymore, either one of these voltages should work fine. I have had several European 220- 50 cycle washers and dryers here for years and they work just fine, except that the dryers tend to tumble too fast so the clothing tends to cling to the drum and doesn't dry properly, so those dryers actually ended up getting recycled. But they did run just fine for many hours.
