I have a Frigidaire Heavy Duty 1-18 Washer that came with the home that I purchased. I have been using the washer for the past 14 years and had no problems other than changing a belt twice. The other day, I noticed water around the washer after running a load. Upon removing the front cover, I have found that the leak is coming from underneath the drum/tub. I found another thread from someone with a similar issue and from the sounds of it, I should just get a new washer. If the fix is really as difficult as everyone is saying (due to finding parts)... where can I go about finding another 1-18 washer? As a single mother with a tight budget, I would much rather spend money on another 1-18 that I know will "run forever" than the "new" washers that have problems as soon as you install them (LoL...but seriously). If it's not super difficult to fix, can someone explain how to go about fixing it? In the picture, I am pointing to the plastic cover underneath that water comes streaming out of from what looks like the center of the drum/tub.
