I'm still awaiting new parts for my washer project and decided to refresh the ~2005 Kenmore (Frigidaire Affinity) dryer. I've been cleaning out lint like crazy and will be installing a new fan/blower housing (fan had stripped off the motor shaft), new drum bearing and new front upper felt seal. The idler pulley and belt seem to be fine.
The motor shaft seems to turn OK but I can hear a faint noise when I spin the shaft by hand. Are these bearings designed that they can be re-lubed ?
There seems to be a hard plastic shield (see 2nd picture) so I don't think I can get turbine oil directly into the bearing. Would there be a "wick" inside to reload with some oil if I can pop off that seal ?
I guess I'll have to pull the motor out but don't know if it is possible to lube the bearings while they are still on the motor shaft nor how to get the bearings off of the shaft - if that is going to be required?
Would appreciate any comments or help on this matter while I've got the dryer torn down over the next week. I searched and read lot's of information on the rear drum bearing but have not found anything about these motor bearings.
