these are great dryers, a perfect match capacity wise to the washer counterpart...I have had several, stacked and side by side...
had the electric, but prefer gas.......the only issue with the electric ones is the heating element is right behind the back wall, and for loads like blankets and comforters should be dried on low, as they don't slide against the bulkhead like stationary ones like a Whirlpool, and you run a risk of scorching the fabric.....mixed loads aren't such a problem......
not actually beneficial, but some of these models reverse tumble....pros and cons, but a neat feature.....
and as mentioned, I prefer the Kenmore version with the stainless drum....
about the only service any of mine have ever needed was that back bearing needing grease, a rather simple job, and a chance to clean out all the lint at the same time.....
