Hi all.. I'm have a problem with my Frigidaire Dryer Model # DCDL. I believe it is a '67 model. when the dryer first starts up it run very quiet and smooth but once it heats up its starts to vibrate and rumble the entire cabinet. I also need to know which way the bearing/bushing goes on the drum shaft. I have taken a couple of pictures of the bearing and each side is different. There is also what looks like a washer and also a spring washer. Do these go on before the bearing or after the bearing is in place but before the circlip that keeps the drum in place. Any info would be appreciated........Thanks a bunch! Mark
