rolls_rapide
ART
The Advanced Rinse Technology I think refers to a complete water change; i.e. water is spun out and drained away, so that each rinse dilutes any remaining detergent to negligable amounts.
My previous AEG had ART, but it plastered laundry to the drum walls, as a clean-water spray was fed from the valves (no pump), via a 4-hole 'jet' located at the top of the doorseal. It would only employ this procedure for the rinses. It also seemed to be more intelligent, in that it would omit a rinse if it sensed it was able to, or add a rinse for too much foam.
My current Zanussi has a pump and its rinsing involves variable-speed tumbling, plastering the laundry, and spin-bursts. It has fixed rinsing (not intelligent enough!).
