Frigidaire Laundry Center
Just a few thoughts:
You might want to mention whether it's a 24" or 27" wide unit.
The plate says 120V, but some people might not think to read that and assume it needs 240V because the dryer is electric.
I might be wrong, but I'm pretty sure at some point in time at least one company made a laundry center that plugged into a regular 240V electric dryer outlet. Am I wrong?
Jim
Jim I have a newer Frigidaire unit like the one he is selling. Mine does have the plug on it that is the same as a dryer. Half of the power goes to the washer and the other half goes to the dryer. It is the only outlet in the laundry closet, so I am limited as to what can go in there when replacement is needed.
Jon
don't recall these being available in GAS, could be wrong.....
but for Electric, I know there were two versions.....
220 electric...which would allow you to run both the washer and dryer at the same time....
110 electric...which would allow you to run only one at a time, but usually there was a slide switch for which one was being used......others would allow for both to run, but if the washer was 'on' the heating element of the dryer would not!..
